    First start of the Stick C Plus 2 + RoverC Pro
    General
    5
    1.6k
    • A
      allbab
      Hello everyone,
      I discover the products from M5Stack, and the programming,
      I received my M5 RoverC Pro as well as my M5Stickc Plus2 this morning
      I flashed my rover with Easy loader
      I installed arduino IDE, launched "Running RoverC.ino" added the libraries of "M5Stickc plus2" and "M5-RoverC" plug my M5Stickc plus2 on my rover and connected via usb to my PC, in arduino IDE I have good chose the com11 port (corresponding to my M5Stickc plus 2 and Roverc pro) and "select other board" on ""M5StickCplus2"
      As I have the M5StickC plus2 I changed the line #include <M5StickCPlus.h> to #include <M5StickCPlus2.h>
      I run "upload" and I get the following error (see screenshot)
      Thanks for your help.
      alt textalt textalt textalt text
      • A
        allbab
        I managed to reduce the errors thanks to gpt chat giving me a better written code (the firmware of the M5 RoverC Pro) but I cannot get a compilation that can be completely injected into the M5StickC Plus 2, here it is: alt textalt text
        • A
          AkAsh98
          Did this problem solved ?
          I am facing the same problem can you help ?
          • kurikoK
            kuriko @AkAsh98
            @AkAsh98 @allbab
            hey, we are updating RoverC library for StickCPlus2 supporting, check it out!
            https://github.com/m5stack/M5-RoverC/tree/master
            • R
              roanevic
              @kuriko
              I just got my RoverC Pro & JoyC, and two M5StickC PLUS2, and I am trying put them together.
              But I can't find the sample code for them (1. Rover C Pro + M5StickC PLUS2 / 2. JoyC + M5StickC PLUS2).
              Does it mean Rover C Pro & JoyC only work with M5StickC PLUS ?
