    No GPS unit examples?
    PRODUCTS
    30.2k
      ajb2k3 @yellowelise
      @yellowelise
      https://github.com/m5stack/M5-ProductExampleCodes/tree/master/Unit/GPS/Arduino/GPSRaw
      • yelloweliseY
        yellowelise
        don't works...
          what doesn't work?
          • yelloweliseY
            yellowelise
            this is the response:
            $GNRMC,,V,,,,,,,,,,M4E
            $GNVTG,,,,,,,,,M
            2D
            $GNZDA,,,,,,56
            $GPTXT,01,01,01,ANTENNA OPEN
            25
            $GNGGA,,,,,,0,00,25.5,,,,,,64
            $GNGLL,,,,,,V,M
            79
            $GPGSA,A,1,,,,,,,,,,,,,25.5,25.5,25.502
            $BDGSA,A,1,,,,,,,,,,,,,25.5,25.5,25.5
            13
            $GPGSV,1,1,0079
            $BDGSV,1,1,00
            68
            $GNVTG,,,,,,,,,M
            2D
            $GNZDA,,,,,,56
            25
            $GNGLL,,,,,,V,M
            79
            13
            $GPGSV,1,1,0079
            $BDGSV,1,1,00
            68
            $GNVTG,,,,,,,,,M
            2D
            $GNZDA,,,,,,56
            25
            • yelloweliseY
              yellowelise
              https://github.com/yellowelise/M5Stack-GPS-Unit
              this code works!
              config:
              M5Stack Fire with PSRAM DISABLED (g17/g16 conflict)
              AT6558 GPS Unit attached at PORT C
              • m5-docsM
                m5-docs @yellowelise
                @yellowelise
                Hi, I guest you are indoors and GPS Unit Example prints raw data needed to be transfer to readable data.
                M5Stack documentation URL
                https://docs.m5stack.com
                • m5-docsM
                  m5-docs @ajb2k3
                  @ajb2k3 Guy, Thanks your reply!
                  • yelloweliseY
                    yellowelise
                    I use tinygps++,
                    how can I change gps serial boud rate?
                    and how can I use 10hz sample rate?
                    m5-docsM 2 Replies Last reply Reply Quote 0
                    • m5-docsM
                      @yellowelise
                      I think you need to reinitialize GPS Unit for changing baudrate.
                      • m5-docsM
                        @yellowelise
                        Write a reinit() function for reinitialization.
                        • yelloweliseY
                          yellowelise
                          @watson
                          No baud in HardwareSerial but Baud in GPS module config, what is the correct NMEA string to config Serial Baud rate communication from GPS to HOST and what is the correct sentence to ser 10hz frequency?
                          es. $GPTXT.......
                          • m5-docsM
                            @yellowelise
                            Hope those will help you.
                            Comes from http://www.icofchina.com/d/file/xiazai/2018-05-23/2b29a8da746eec0ef1dcd9deae895298.zip
                            • yelloweliseY
                              yellowelise
                              GOOOOOOD!!!
                              Works fine for me!
                              tnx very much!
