    No GPS unit examples?
    14 Posts 3 Posters 32.0k Views 1 Watching
    • yelloweliseY Offline
      yellowelise
      Hi, I receive today GPS unit AT6558, but in library I don't find any examples, any examples are welcome.
        ajb2k3 @yellowelise
        @yellowelise
        https://github.com/m5stack/M5-ProductExampleCodes/tree/master/Unit/GPS/Arduino/GPSRaw
          yellowelise
          don't works...
            what doesn't work?
              yellowelise
              this is the response:
              $GNRMC,,V,,,,,,,,,,M4E
              $GNVTG,,,,,,,,,M
              2D
              $GNZDA,,,,,,56
              $GPTXT,01,01,01,ANTENNA OPEN
              25
              $GNGGA,,,,,,0,00,25.5,,,,,,64
              $GNGLL,,,,,,V,M
              79
              $GPGSA,A,1,,,,,,,,,,,,,25.5,25.5,25.502
              $BDGSA,A,1,,,,,,,,,,,,,25.5,25.5,25.5
              13
              $GPGSV,1,1,0079
              $BDGSV,1,1,00
              68
              $GNVTG,,,,,,,,,M
              2D
              $GNZDA,,,,,,56
              25
              $GNGLL,,,,,,V,M
              79
              13
              $GPGSV,1,1,0079
              $BDGSV,1,1,00
              68
              $GNVTG,,,,,,,,,M
              2D
              $GNZDA,,,,,,56
              25
                yellowelise
                https://github.com/yellowelise/M5Stack-GPS-Unit
                this code works!
                config:
                M5Stack Fire with PSRAM DISABLED (g17/g16 conflict)
                AT6558 GPS Unit attached at PORT C
                • m5-docsM Offline
                  m5-docs @yellowelise
                  @yellowelise
                  Hi, I guest you are indoors and GPS Unit Example prints raw data needed to be transfer to readable data.
                  M5Stack documentation URL
                  https://docs.m5stack.com
                  • m5-docsM Offline
                    m5-docs @ajb2k3
                    @ajb2k3 Guy, Thanks your reply!
                      yellowelise
                      I use tinygps++,
                      how can I change gps serial boud rate?
                      and how can I use 10hz sample rate?
                      m5-docsM 2 Replies Last reply Reply Quote 0
                      • m5-docsM Offline
                        @yellowelise
                        I think you need to reinitialize GPS Unit for changing baudrate.
                        • m5-docsM Offline
                          @yellowelise
                          Write a reinit() function for reinitialization.
                            yellowelise
                            @watson
                            No baud in HardwareSerial but Baud in GPS module config, what is the correct NMEA string to config Serial Baud rate communication from GPS to HOST and what is the correct sentence to ser 10hz frequency?
                            es. $GPTXT.......
                            • m5-docsM Offline
                              @yellowelise
                              Hope those will help you.
                              Comes from http://www.icofchina.com/d/file/xiazai/2018-05-23/2b29a8da746eec0ef1dcd9deae895298.zip
                                yellowelise
                                GOOOOOOD!!!
                                Works fine for me!
                                tnx very much!
