    How to use M5Unit-PoESP32 ?
    Units
    2.0k
    • F
      frankqc
      I purchased a Power Over Ethernet ESP32 (M5Unit-PoESP32) thinking I could run sensors and send the data over to either Home Assistant, Blynk or my own server. But receiving the unit I realize I have no idea how to use it even after reading all the online doc.
      I purchased a USB Downloader Kit and I'm able to connect to it with my computer now and download the firmware.
      1. In Arduino IDE what unit type should I select? The closest I found was "ESP32-WROOM-DA" but have never been able to see the serial output.
      2. How do people use this device with the default firmware ??
      3. Is there I2C pins I can use to plug sensors ?
      4. In my Arduino IDE code I usually include WiFi.h. What is the replacement to have my same code work over ethernet?
      #include <WiFi.h> // importing all the required libraries
      #include <WiFiClient.h>
      Thanks!
      Frank
      • robskiR
        robski
        @frankqc said in How to use M5Unit-PoESP32 ?:
        M5Unit-PoESP32
        do you have any other controller to work with it?
        The way I see it is that ie you have let say M5Core with some I2C units (sensors) connected to it
        then add your M5Unit-PoESP32 connected to M5Core too over UART port (blue) to give whole setup access to local network and power ...
        docs examples etc
          Hello @frankqc
          Scenario A : PoESP32 runs default AT command firmware and is used as unit connected to anther core.
          Scenario B : PoESP32 runs alternate firmware, runs standalone and is not a unit.
          Re 1. : for scenario B try something like a generic ESP32 board, e.g. ESP32 Dev Module
          Re 2. : for scenario A like @robski mentioned the other core sends AT commands to the PoESP32 unit. See examples here - section Example/Arduino.
          Re 3. : for scenario B the Groove port should be usable for I2C.
          Re 4. : for scenario B see example here.
