    Timer Camera X with Fingerprint FPC1020A
    7 Posts 2 Posters 4.0k Views
    • L Offline
      Lubos22
      Hi guys please im having ESP32 PSRAM Timer Camera X and i bought Finger Print Sensor Unit (FPC1020A), please could someone help me create some test code if fingerprint sensor is working. Its connected via Grove Cable. I cant make it work.... like im not getting any value .. Maybe i just doing some mistake with rx, tx. i just dont know how to make it
      using this #include "M5_FPC1020A.h" library. #include "M5_FPC1020A.h"
      FingerPrint Finger;
      Serial.begin(115200);
      delay(2000);
      Serial.println("FingerPrint Sensor Setup");
      uint8_t rx = 16;
      uint8_t tx = 17;
      Finger.begin(&Serial2, rx, tx);
      uint8_t addUserResult = Finger.fpm_addUser(1, 1);
      if (addUserResult == ACK_SUCCESS) {
          Serial.println("User added successfully!");
      } else {
          Serial.print("Failed to add user. Error code: ");
          Serial.println(addUserResult);
      // Compare fingerprints
      uint8_t compareResult = Finger.fpm_compareFinger();
      if (compareResult == ACK_SUCCESS) {
          Serial.println("Fingerprints match!");
      } else if (compareResult == ACK_NOUSER) {
          Serial.println("No fingerprints enrolled.");
      } else if (compareResult == ACK_TIMEOUT) {
          Serial.println("Fingerprint matching timeout.");
      } else {
          Serial.print("Fingerprints do not match. Error code: ");
          Serial.println(compareResult);
      delay(10000);
        Hello @Lubos22
        Timer Camera X Groove port is GPIO4 and GPIO13. See back of camera or pinmap here.
        • L Offline
          Lubos22
          Thank you for your reply. So should i just change rx and tx ? uint8_t rx = 13;
          uint8_t tx = 4; Because i tried that Failed to add user. Error code: 1
          Fingerprints do not match. Error code: 1.
          Dont know ... What to do please help.
            Hello @Lubos22
            unfortunately I do not have a fingerprint unit to test with so I cannot say what else might be wrong. Sorry.
            • L Offline
              Lubos22
              Thank you, Can anyone else help please?
              • L Offline
                Lubos22
                // Print the current add mode
                Serial.println(Finger.fpm_readAddMode());
                // Add a user with user number 21 and permission 1
                uint8_t addUserResult = Finger.fpm_addUser(21, 1);
                // Print the result of adding the user
                Serial.print("Add user result: ");
                // Print additional details for debugging
                for (int i = 0; i < 9; i++) {
                Serial.print("RxBuf[");
                Serial.print(i);
                Serial.print("]: ");
                Serial.println(Finger.RxBuf[i], HEX);
                output when the finger is not placed on the fingerprint:
                Add user result: 1
                RxBuf[0]: FF
                RxBuf[1]: 0
                RxBuf[2]: 0
                RxBuf[3]: 0
                RxBuf[4]: 0
                RxBuf[5]: 0
                RxBuf[6]: 0
                RxBuf[7]: 0
                RxBuf[8]: 0
                output when the finger is placed on the fingerprint:
                Add user result: 1
                RxBuf[0]: FF
                RxBuf[1]: FF
                RxBuf[2]: FF
                RxBuf[3]: FF
                RxBuf[4]: FF
                RxBuf[5]: FF
                RxBuf[6]: FF
                RxBuf[7]: FF
                RxBuf[8]: 0
                • L Offline
                  Lubos22
                  and when I try to test 100x by putting my finger... I have Add user result: 0 but the chance is 1/100. So could it be the fingerprint unit is broken?
                  RxBuf[0]: F5
                  RxBuf[1]: 3
                  RxBuf[2]: 0
                  RxBuf[3]: 0
                  RxBuf[4]: 0
                  RxBuf[5]: 0
                  RxBuf[6]: 3
                  RxBuf[7]: F5
                  RxBuf[8]: 0
