    My M5stick doesnt work, after i instaled unofficial marauder!
    6 Posts 2 Posters 4.7k Views
      severopotter
      I can run burn normally, but my screen simply won't turn on, the LEDs also work!
      The firmware
        ajb2k3 @severopotter
        @severopotter that’s for the plus2.
        You need to erase and re burn UIFlow.
        It’s not the device broken, it the version uses a different hardware configuration
          severopotter
          But, my device is the plus2
          i've tried erase:
          and burn again
          firmware monitor:
          and it still doesn't work :(
            You didn’t say that earlier.
            Erase the firmware and install arduino or UIFlow firmware and avoid
            S 2 Replies Last reply Reply Quote 0
              severopotter @ajb2k3
              @ajb2k3 but I'm not doing that in the images above?
                @ajb2k3 i've tried
                #include "M5StickCPlus2.h"
                auto cfg = M5.config();
                StickCP2.begin(cfg);
                StickCP2.Display.setRotation(1);
                StickCP2.Display.setTextColor(RED);
                StickCP2.Display.setTextDatum(middle_center);
                StickCP2.Display.setTextFont(&fonts::Orbitron_Light_24);
                StickCP2.Display.setTextSize(1);
                StickCP2.Display.drawString("Power LED", StickCP2.Display.width() / 2,
                StickCP2.Display.height() / 2);
                // inside power red led control
                StickCP2.Power.setLed(1);
                delay(1000);
                StickCP2.Power.setLed(0);
                delay(1000);
                in arduino, but the display didn't work
