Cannot canvas.drawString() onto canvas. (M5PaperTouchArea)
I have made a small modification to RAWSEQ'sexcellent M5PaperTouchArea project.
I am trying to use the spare white area as an output canvas. I can place the CanvasOP (output canvas) correctly and I can check it is really there by filling it in different shades and moving it around. but I cannot write into it. Any canvasOP.drawString() commands seem to be ignored. I have tried changing the text color, size and position but I cannot seem to get text to show up on the pushed canvasOP.
#include <M5EPD.h> #include "M5PaperTouchArea.h" #include "MPlusFontsSubset.h" // M5EPD Canvas M5EPD_Canvas canvas(&M5.EPD); M5EPD_Canvas canvasOP(&M5.EPD); // Module (Grid & TouchArea) M5PaperTouchAreas _m5pta; // Module (Grid Only) GridUtil _gu; void setup() { // Display Setup M5.begin(); M5.EPD.SetRotation(90); M5.TP.SetRotation(90); M5.EPD.Clear(true); canvas.loadFont(MPlusFontsSubset, sizeof(MPlusFontsSubset)); canvas.createCanvas(540, 960); canvas.createRender(48, 256); canvas.fillRect(0, 0, 540, 960, 10); _m5pta.current_canvas = &canvas; _m5pta.getGutil()->setVertical(true); _gu.setVertical(true); // Event Setting _m5pta.e_touch.func = bTouch; _m5pta.e_release.func = bRelease; // Change Default Setting _m5pta.default_font_size = 48; _m5pta.default_radius = 15; _m5pta.default_font_linepos = 6; _m5pta.default_bc = { 13, 0, 0 }; // Touch Area Test _m5pta.add_grid(1, 1, 1, 1, "B1", "b1"); _m5pta.add_grid(2, 1, 1, 1, "B2", "b2"); _m5pta.add_grid(3, 1, 1, 1, "B3", "b3"); _m5pta.add_grid(4, 1, 1, 1, "B4", "b4"); _m5pta.add_grid(5, 1, 1, 1, "B5", "b5"); _m5pta.add_grid(1, 2, 3, 1, "B6", "b6"); _m5pta.add_grid(4, 2, 2, 1, "B7", "b7"); _m5pta.add_grid(1, 3, 2, 1, "B8", "b8"); _m5pta.add_grid(3, 3, 3, 1, "B9", "b9"); _m5pta.add_grid(1, 4, 5, 1, "B10 Steve", "Steve"); _m5pta.add_grid(1, 5, 2, 1, "B11", "b11"); //_m5pta.add_grid(3, 5, 3, 2, "B16", "b16");//added by steve _m5pta.add_grid(1, 6, 2, 2, "B12", "b12"); _m5pta.add_grid(3, 7, 3, 3, "B13", "b13"); _m5pta.add_grid(1, 8, 2, 1, "B14", "b14"); _m5pta.add_grid(1, 9, 2, 1, "B15", "b15"); _m5pta.draw(); // Grid Draw Test // GURect g = _gu.convert(3, 5, 3, 2); // canvas.setTextColor(10); // canvas.fillRect(g.x, g.y, g.w, g.h, 0); canvas.pushCanvas(0, 0, UPDATE_MODE_GC16); /* Serial.print(g.x); Serial.print("..."); Serial.print(g.y); Serial.print("..."); Serial.print(g.w); Serial.print("..."); Serial.print(g.h);*/ //230...440...290...180 g.cordinates canvasOP.createCanvas(290, 180); //canvasOP.fillCanvas(5); canvasOP.setTextSize(4); canvasOP.setTextColor(15); canvasOP.drawString("Hello", 20, 100); canvasOP.pushCanvas(230, 440, UPDATE_MODE_GC16); } // Touch Event void bTouch(M5PTAEventContext& ct) { Serial.println("T:" + ct.code); } // Release Event void bRelease(M5PTAEventContext& ct) { Serial.println("R:" + ct.code); } void loop() { _m5pta.loop(); } -
I am just starting out with the M5Paper and a lot of things are taking some getting use to. I thought about deleting this thread when I found out how easy the solution was but then I thought that maybe this will help someone else. So here is the solution:
You have to declare a font for use in the canvasOP. So adding his line after creating canvasOP fixes the problem:
canvasOP.setFreeFont(&FreeSerif24pt7b);
