    M5Unit-ENV library for PlatformIO is not up-to-date
    1.8k
    • AmedeeA
      Amedee
      FYI, I discovered that the M5Unit-ENV library for PlatformIO is missing at least 1 commit compared to the one for the Arduino IDE, which is strange as they both advertise the same version: 0.0.8
      I suspect that 0.0.8 has been re-issued as the release date on GitHub is from 2 weeks ago, an PlatformIO m5stack/M5Unit-ENV says: "Last Modified: a month ago"...
      In the meantime, if you need the latest version, you can use the GitHub URL instead of the name in your lib_deps
