    Cant Get RS485 TTL Convertor Working
    Modules
    2.8k
    • J
      jkeyser
      Trying to get this working, but am unable to send/receive anything at all https://shop.m5stack.com/products/rs485-module
      Ive tried on the core (pins 17/16) and core 2 (pins 14/13).
      For testing im just running this very basic code but can only get 'None' as a response. To send data im just using YAT and a USB->RS485 convertor which I have tested using a known-working device. Any ideas of what might be wrong?
      from m5stack import *
      from m5ui import *
      from uiflow import *
      uart1 = machine.UART(1, tx=14, rx=13)
      uart1.init(9600, bits=8, parity=None, stop=1)
      while True:
        print(uart1.readline())
        wait_ms(500)
      • J
        jkeyser @jkeyser
        @jkeyser if anyone comes across this in the future, at least on the core 2 the correct pins are 33/32
        • G
          gavin67890 @jkeyser
          Hi @jkeyser, Did you get it working on pins 32/33?
          If not, these posts might help you.
          https://forum.m5stack.com/topic/5615/m5-tough-uart-communication/12
          https://forum.m5stack.com/topic/1546/micro-bit/8
          I just wanted to clarify because I think that UART is indeed on pins 13/14.
          If you see the table in this document
          https://docs.m5stack.com/en/core/core2
          PORT. PIN Note:
          PORT-A(Red) 32/33 I2C
          PORT-B(Black) 26/36 DAC/AD
          PORT-C(Blue) 13/14 UART
          The Groove port on the side of the Core2 is I2C (A/Red), which is probably where the 32/33 comes from (you may be able to switch mode and run on 32/33, please confirm if you can). The port of the TTL to RS485 convertor is UART (C/Blue). You can pin this directly onto a naked Core2 with a Groove to Dupont cable or a base with UART (C/Blue) port. In my case, I have CatM IoT base or you might have the blue port on the M5GO2 base available, which I think is default supplied with the Core2. Best of luck.
          • G
            gavin67890
            This, at approx. 5 mins in, might help with the I2C port reassigning for UART (I recalled I used it for StickC).
            https://www.youtube.com/watch?v=zSUyC-SQOEU
            • J
              jkeyser @gavin67890
              @gavin67890 I was able to get it working with 32/33 just by assigning with
              uart1 = machine.UART(1, tx=32, rx=33)
              which it looks like is the same the guy did in the video
