    Pb.HUB will not connect. [Fixed]
    18 Posts 3 Posters 16.0k Views 1 Watching
    • I Offline
      IsoEek @ajb2k3
      @ajb2k3 Still no joy. 🤔This is from the terminal.
      ets Jun 8 2016 00:22:57
      rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
      configsip: 188777542, SPIWP:0xee
      mode:DIO, clock div:1
      load:0x3fff0018,len:4
      load:0x3fff001c,len:5228
      load:0x40078000,len:12908
      ho 0 tail 12 room 4
      load:0x40080400,len:3512
      entry 0x4008063c
         _  __ _
      _ ()/ | | _____ __
      | |/ _ \ \ /\ / /
      | || | | | | () \ V V /
      _
      ,||| ||___/ _/_/
      APIKEY: A2DCA138
      File "flow/m5cloud.py", line 82, in _exec_fun
      File "<string>", line 9, in <module>
      File "unit.py", line 186, in get
      File "<string>", line 1, in <module>
      File "units/_pbhub.py", line 15, in init
      File "units/_pbhub.py", line 21, in _available
      Unit: Pb.hub unit maybe not connect
      1_1692054157240_uiflow_block_PB_Hub_Atom.png 0_1692054157240_Atom Pb Hub Wiring sm.png
      • I Offline
        IsoEek
        I can't connect PbHUB V1.1 to Atom Lite or Tough.
          pandian.nano
          First check if pbhub is connected or not? Check whether the i2c scan device result is [0x61] or [97].
          I 1 Reply Last reply Reply Quote 1
          • I Offline
            IsoEek @pandian.nano
            @pandian-nano Thanks for the suggestion and help. This is what is in the terminal.
            === from m5stack import *
            === from m5stack_ui import *
            === from uiflow import *
            === import i2c_bus
            === import time
            === import unit
            === screen = M5Screen()
            === screen.clean_screen()
            === screen.set_screen_bg_color(0xFFFFFF)
            === pbhub_0 = unit.get(unit.PBHUB, unit.PORTA)
            === i2c0 = i2c_bus.easyI2C(i2c_bus.PORTA, 0x00, freq=400000)
            === i2c0.addr=(0x68)
            === while True:
            === print(i2c0.scan())
            === wait_ms(200)
            === wait_ms(2)
            File "<stdin>", line 10, in <module>
            File "unit.py", line 190, in get
            • I Offline
              IsoEek
              I have lost track of how many times ive erased and downloaded the firmware. This is the last Terminal screen.
              Connected to Serial Port!
              ( �m�!0ϟ��( �m�!0���
              _ __ _
              _ ()/ | | _____ __
              | |/ _ \ \ /\ / /
              | || | | | | () \ V V /
              _
              ,||| ||___/ _/_/
              APIKEY: 2F9D3FE8
              File "main.py", line 12, in <module>
              MicroPython b0cb55176-dirty on 2023-08-03; M5Stack with ESP32
              I felt I was making decent progress at first. I have had so many failures now, I question the little bit I do know. Tried Uiflow V2 but Pb.Hub is not available.
                pandian.nano
                0_1692167268589_7e4f250d-e7a6-4a0f-87f9-fff2bafa0fd7-a90fa071078c2fe2db6a48d44bc9637.jpg
                Please check again and check the result
                • I Offline
                  @pandian-nano Thanks. This is the out come. I looked up the Hex for 96 and I get 0x60. I believe I need to set init and/or set the new address. Is the answer as simple as using the Write Memory Data under I2C Master? Is the included block what I need to burn? I'm doing my best to learn this, but damn there is a lot to learn!
                  I tried using this code and I had no change.
                    pandian.nano
                    @IsoEek
                    • Please check again and check the result 0x61[97]
                    • If you get 0x61 result then your pbhub i2c address was changed from 0x60 to 0x61
                    • I Offline
                      @pandian-nano said in Pb.HUB will not connect.:
                      97
                      I now get [97] and True. I just tried using digital and analog read. Both are working as expected. That was a really cool party trick! Where can I read more about what you walked me through. I obviously have no issues making bad code. I need to know how to clean up my own messes and how to debug. Thank you so much for the help. I appreciate it more than you know.
                        pandian.nano
                        @IsoEek https://docs.m5stack.com/en/quick_start/m5core/uiflow
                        • I Offline
                          @pandian-nano Thank you. I have read through that several times and it makes no more sense than the time before. I'll eventually come across something that I understand and it will sink in. Thanks again.
