    Pb.HUB will not connect. [Fixed]
    18 Posts 3 Posters 16.0k Views 1 Watching
    • I Offline
      IsoEek @IsoEek
      @isoeek Okay, I think I'm the cause of the fault as it's not working now. All I'm trying to do is run 2 maybe 3 mosfet dc speed controllers with a PWM signal from the Pb.HUB. If its not capable I'll use the EXT.IO2.
        Ahh power draw issues.
        Try providing separate power to the devices but only connect the signal and GND pins to the PbHub.
        I 2 Replies Last reply Reply Quote 0
        • I Offline
          IsoEek @ajb2k3
          @ajb2k3 I have a few Type C 2 Grove. I cant believe I didnt think about that. Thank you. I'll let you know how it goes.
          • I Offline
            IsoEek @ajb2k3
            @ajb2k3 Still no joy. 🤔This is from the terminal.
            ets Jun 8 2016 00:22:57
            rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
            configsip: 188777542, SPIWP:0xee
            mode:DIO, clock div:1
            load:0x3fff0018,len:4
            load:0x3fff001c,len:5228
            load:0x40078000,len:12908
            ho 0 tail 12 room 4
            load:0x40080400,len:3512
            entry 0x4008063c
               _  __ _
            _ ()/ | | _____ __
            | |/ _ \ \ /\ / /
            | || | | | | () \ V V /
            _
            ,||| ||___/ _/_/
            APIKEY: A2DCA138
            File "flow/m5cloud.py", line 82, in _exec_fun
            File "<string>", line 9, in <module>
            File "unit.py", line 186, in get
            File "<string>", line 1, in <module>
            File "units/_pbhub.py", line 15, in init
            File "units/_pbhub.py", line 21, in _available
            Unit: Pb.hub unit maybe not connect
            1_1692054157240_uiflow_block_PB_Hub_Atom.png 0_1692054157240_Atom Pb Hub Wiring sm.png
            • I Offline
              IsoEek
              I can't connect PbHUB V1.1 to Atom Lite or Tough.
                pandian.nano
                First check if pbhub is connected or not? Check whether the i2c scan device result is [0x61] or [97].
                I 1 Reply Last reply Reply Quote 1
                • I Offline
                  IsoEek @pandian.nano
                  @pandian-nano Thanks for the suggestion and help. This is what is in the terminal.
                  === from m5stack import *
                  === from m5stack_ui import *
                  === from uiflow import *
                  === import i2c_bus
                  === import time
                  === import unit
                  === screen = M5Screen()
                  === screen.clean_screen()
                  === screen.set_screen_bg_color(0xFFFFFF)
                  === pbhub_0 = unit.get(unit.PBHUB, unit.PORTA)
                  === i2c0 = i2c_bus.easyI2C(i2c_bus.PORTA, 0x00, freq=400000)
                  === i2c0.addr=(0x68)
                  === while True:
                  === print(i2c0.scan())
                  === wait_ms(200)
                  === wait_ms(2)
                  File "<stdin>", line 10, in <module>
                  File "unit.py", line 190, in get
                  • I Offline
                    IsoEek
                    I have lost track of how many times ive erased and downloaded the firmware. This is the last Terminal screen.
                    Connected to Serial Port!
                    ( �m�!0ϟ��( �m�!0���
                    _ __ _
                    _ ()/ | | _____ __
                    | |/ _ \ \ /\ / /
                    | || | | | | () \ V V /
                    _
                    ,||| ||___/ _/_/
                    APIKEY: 2F9D3FE8
                    File "main.py", line 12, in <module>
                    MicroPython b0cb55176-dirty on 2023-08-03; M5Stack with ESP32
                    I felt I was making decent progress at first. I have had so many failures now, I question the little bit I do know. Tried Uiflow V2 but Pb.Hub is not available.
                      pandian.nano
                      0_1692167268589_7e4f250d-e7a6-4a0f-87f9-fff2bafa0fd7-a90fa071078c2fe2db6a48d44bc9637.jpg
                      Please check again and check the result
                      • I Offline
                        @pandian-nano Thanks. This is the out come. I looked up the Hex for 96 and I get 0x60. I believe I need to set init and/or set the new address. Is the answer as simple as using the Write Memory Data under I2C Master? Is the included block what I need to burn? I'm doing my best to learn this, but damn there is a lot to learn!
                        I tried using this code and I had no change.
                          pandian.nano
                          @IsoEek
                          • Please check again and check the result 0x61[97]
                          • If you get 0x61 result then your pbhub i2c address was changed from 0x60 to 0x61
                          • I Offline
                            @pandian-nano said in Pb.HUB will not connect.:
                            97
                            I now get [97] and True. I just tried using digital and analog read. Both are working as expected. That was a really cool party trick! Where can I read more about what you walked me through. I obviously have no issues making bad code. I need to know how to clean up my own messes and how to debug. Thank you so much for the help. I appreciate it more than you know.
                              pandian.nano
                              @IsoEek https://docs.m5stack.com/en/quick_start/m5core/uiflow
                              • I Offline
                                @pandian-nano Thank you. I have read through that several times and it makes no more sense than the time before. I'll eventually come across something that I understand and it will sink in. Thanks again.
