    why image+ is not showing on coreS3?
    Cores
    2.7k
      syrinebh
      Hello, I'm trying to load image+ on coreS3 but I don't know why it's not showing however in the uiflow2.0 the right picture is showing. But when I try to run the code on the real device only the default image is showing.
      image_plus0 = ImagePlus("https://encrypted-tbn0.gstatic.com/images?q=tbn:ANd9GcTHZAq08u4YaR0Jsu2CgeptdxC74y-9QEeFYEAb6YHP&s", 78, 41, True, 3000, default_img="res/img/default.png")
        ajb2k3 @syrinebh
        @syrinebh is the image below a certain data size of 50kb?
        Can the s3 communicate with the server hosting the image?
        Is the image less than 320X240 pixels in dimension?
        There could be many reasons but I noticed the default setting, that should be set to the image not default
          syrinebh
          @ajb2k3 I'm getting the image from images section in google
