    Core S3 SD/TF Card Issues
    4.5k
    • D
      djh82uk
      Hi Guys,
      I have a core S3 that I am trying to program via the Arduino IDE as UiFlow 2 is missing a lot of the capabilites for the S3.
      I have also tried this with a standard ESp32 S3 board and get the same issue but could do with some guidance.
      My Code:
          // Include required libraries
          #include "M5CoreS3.h"
          #include "Arduino.h"
          #include "Audio.h"
          #include "SD.h"
          #include "FS.h"
          // microSD Card Reader connections
          #define SD_CS         15
          #define SPI_MOSI      37
          #define SPI_MISO      35
          #define SPI_SCK       36
          // I2S Connections
          #define I2S_DOUT      39
          #define I2S_BCLK      40
          #define I2S_LRC       41
          // Create Audio object
          Audio audio;
              // Set microSD Card CS as OUTPUT and set HIGH
              pinMode(SD_CS, OUTPUT);
              digitalWrite(SD_CS, HIGH);
              // Initialize SPI bus for microSD Card
              SPI.begin(SPI_SCK, SPI_MISO, SPI_MOSI);
              USBSerial.print("MOSI: ");
              USBSerial.println(MOSI);
              USBSerial.print("MISO: ");
              USBSerial.println(MISO);
              USBSerial.print("SCK: ");
              USBSerial.println(SCK);
              USBSerial.print("SS: ");
              USBSerial.println(SS);
              SPIClass SPI1(HSPI);
              // Start microSD Card
              if(!SD.begin(SD_CS, SPI1))
                USBSerial.println("Error accessing microSD card!");
                while(true);
              // Setup I2S
              audio.setPinout(I2S_BCLK, I2S_LRC, I2S_DOUT);
              USBSerial.println("Pinout Set!");
              // Set Volume
              audio.setVolume(5);
              USBSerial.println("Volume Set Set!");
              // Open music file
              audio.connecttoFS(SD,"/demo.mp3");
              USBSerial.println("File Open!");
          void loop()
              audio.loop();
      Basically, I keep getting the message "Error accessing microSD card!" on the terminal. Pretty sure I have the pins right? And the card is formatted to FAT32.
      For some reason, I just cannot get it to read
      Any Ideas?
        Hello @djh82uk
        firstly SD_CS is GPIO 4 - see pin map here.
        Secondly it looks like the TFT (which also uses SPI) uses MISO as DC. From an ESP32 perspective MISO is an input but DC needs to be an output. So the TFT driver configures the MISO GPIO to an output. This conflicts with the SD card, which is on the same SPI bus and requires MISO to be an input. Not sure how to resolve that so that TFT and SD card can coexist.
        Thirdly the M5CoreS3 library sets the voltage for the SD card incorrectly to 1.3 V instead of 3.3 V. I posted a PR for that.
        A simple SD card example which works for me (but it disables the TFT) is here.
          Hello @djh82uk
          I found a way to use the SD card w/o compromising the TFT. You can find it here.
          • L
            LordInchcape @felmue
            @felmue Hello. Does a micropython example of this exist? Thanks.
              felmue @LordInchcape
              Hello @LordInchcape
              not that I know of. That said, have you tried to see what Micropython code UIFlow2 produces?
