    multiple i2c bugs
    10 Posts 4 Posters 12.3k Views
      HWTaro9
      I am trying to get the CoreS3's proximity and ambient light sensor to work in UiFlow2.0 and I am having these problems.
      1: i2c "Generate START condition" block shows this error "OSError: I2C operation not supported"
      2: i2c "Scan Device" block returns addresses, but the address for the LTR553 (0x23) does not show up.
      3: You need an object with buffer protocol to send data via i2c but something with buffer protocol (like bytearray) does not work.
      Any help or bug fix/update is much appreciated!
      • felmueF Online
        Hello @HWTaro9
        1: not sure when this is actually needed.
        2: I2C scan returns a list with decimal values (not hex) therefore you should be looking for the decimal value 35 (=0x23) in the list.
        3: I am able to write to and read from the light sensor like below:
          HWTaro9
          Thank you very much for the info and code! But the reason I need to send a start command is because the microphone decoder only sends code after a start condition is sent, and I'm not sure that it is sent automatically.
          • felmueF Online
            Hello @HWTaro9
            it is my understanding that audio data from the microphones are being sent via I2S (not I2C), no?
            Do you have a document explaining the I2C commands of the ES7210?
              HWTaro9
                HWTaro9 @felmue
                @felmue page 4 in this document http://www.everest-semi.com/pdf/ES7210 PB.pdf
                • felmueF Online
                  Hello @HWTaro9
                  that is only the general description of how I2C works. Or am I missing something?
                  I am looking for a list of register addresses which can be read and write to.
                    aleekwen @felmue
                    @felmue this IDE code works for me on the CoreS3 - I had to cobble together code from various sources to get this to work (and still use the CoreS3 lib)
                    #define LTR553_ADDR 0x23
                    void writeRegister8(uint8_t _address, uint8_t subAddress, uint8_t data, uint32_t freq) {
                    Wire1.beginTransmission(_address);
                    Wire1.write(subAddress);
                    Wire1.write(data);
                    Wire1.endTransmission();
                    uint8_t readRegister8(uint8_t _address, uint8_t subAddress, uint32_t freq) {
                    Wire1.requestFrom(_address, (size_t)1);
                    return Wire1.read();
                    void readRegister(uint8_t _address, uint8_t subAddress, uint8_t buff[], int size, uint32_t freq) {
                    Wire1.requestFrom(_address, (size_t)size);
                    for (int i = 0; i < size; i++) {
                    buff[i] = Wire1.read();
                    bool LTR553Init() {
                    // soft reset
                    uint8_t value_r = readRegister8(LTR553_ADDR, 0x80, 100000L);
                    value_r &= (~0x02);
                    uint8_t value_w = value_r | 0x02;
                    writeRegister8(LTR553_ADDR, 0x80, value_w, 100000L);
                    // PS Led Pluse
                    writeRegister8(LTR553_ADDR, 0x83, 0x0F, 100000L);
                    // ALS Active Mode
                    value_r &= (~0x01);
                    value_w = value_r | 0x01;
                    // PS Active Mode
                    value_r = readRegister8(LTR553_ADDR, 0x81, 100000L);
                    value_r &= (~0x03);
                    value_w = value_r | 0x03;
                    writeRegister8(LTR553_ADDR, 0x81, value_w, 100000L);
                    return true;
                    uint32_t GetLTR553AlsCh0Value() {
                    uint8_t buffer[2];
                    uint32_t result;
                    readRegister(LTR553_ADDR, 0x8A, buffer, 2, 100000L);
                    result = (buffer[1] << 8) | buffer[0];
                    return result;
                    uint32_t GetLTR553AlsCh1Value() {
                    uint8_t buffer[2];
                    uint32_t result;
                    readRegister(LTR553_ADDR, 0x88, buffer, 2, 100000L);
                    return result;
                    uint16_t GetLTR553PsValue() {
                    uint8_t buffer[2];
                    uint16_t result;
                    readRegister(LTR553_ADDR, 0x8D, buffer, 2, 100000L);
                    buffer[0] &= 0xFF;
                    buffer[1] &= 0x07;
                    return result;
                    call the Init from setup and call the Get* ones as you need
                    • felmueF Online
                      Hello @aleekwen
                      thank you for the extensive code example.
                      However, the original topic was for UIFlow 2.0 (not IDE code) and the user having difficulties is @HWTaro9.
                      That said, it is still good to know that it works when using IDE code.
                      • IAMLIUBOI Offline
                        IAMLIUBO
                        @HWTaro9 @felmue @aleekwen
                        Hi, new firmware now suppport LTR553 sensor.
