COM.LTE Module not responding
Using this module with an external power supply along with the Core 2. No other modules attached at the moment.
https://shop.m5stack.com/products/com-lte-modulesim7600gOnly code uploaded is the example provided on uiflow, but i cant get any sort of response. The only output i get is "Text" in the top left of the screen. The program seems to hang during init and never makes it past that point. Confirmed DC power switch is on the correct setting, as well as the tx/rx dip switches.
Flashing the easyloader results in no output to the screen, as well as a high pitched ringing from the modem
Setting COM.X to true on m5burner gives the error 'module stable timeout'
from m5stack import *
from m5stack_ui import *
from uiflow import *
from comx.lte import LTEscreen = M5Screen()
screen.clean_screen()
screen.set_screen_bg_color(0xFFFFFF)resp = None
label0 = M5Label('label0', x=33, y=36, color=0x000, font=FONT_MONT_14, parent=None)
label1 = M5Label('label1', x=37, y=63, color=0x000, font=FONT_MONT_14, parent=None)
label2 = M5Label('label2', x=35, y=91, color=0x000, font=FONT_MONT_14, parent=None)
label3 = M5Label('label3', x=36, y=114, color=0x000, font=FONT_MONT_14, parent=None)lte = LTE(tx=13, rx=5)
label0.set_text(str(lte.check_status()))
label1.set_text(str(lte.get_single_quality()))
label2.set_text(str(lte.get_network_registration()))
label3.set_text(str(lte.get_gprs_network_registration()))
while True:
if str((lte.get_gprs_network_registration())) == '1':
# echo "test"
resp = lte.http_get('http://www.m2msupport.net/m2msupport/test.php')
if resp:
label4.set_text(str(resp[1]))
wait_ms(2) -
Thanks, while looking into that I found i wasn't also unable to open any sort of connection to send AT commands. Turns out i misunderstood the dip settings for the core 2. Set to 16/17 on the modem and 14/13 on uiflow init and i have communication now. -
