    M5-TOUGH / unable to change display brightness
    7 Posts 4 Posters 9.2k Views
    • E Offline
      erazor
      Hi.
      I'm using the latest library via Platformio (lib_deps = https://github.com/m5stack/M5Tough) and am unable to change the display brightness.
      My code is as simple as this:
      M5.Axp.SetLcdVoltage(2500);
      This does not change anything on the display.
      It works with the M5-Core2 module though.
      Can anybody confirm the SetLcdVoltage works for the M5-TOUGH?
      Thanks and have a great week.
        flypeek
        no M5-Core to try
        https://github.com/m5stack/M5Tough/blob/master/src/M5Display.h
        class M5Display : public TFT_eSPI {
            public:
              static M5Display* instance;
              M5Display();
              void begin();
              void sleep();
              void wakeup();
              void setBrightness(uint8_t brightness);
              void clearDisplay(uint32_t color=ILI9341_BLACK) { fillScreen(color); }
              void clear(uint32_t color=ILI9341_BLACK) { fillScreen(color); }
              void display() {}
        so you can try this
        #include <M5Display.h>
        M5.Lcd.setBrightness(value);    //uint8_t  Brightness (0: Off - 255:Full)
        • E Offline
          erazor
          Hi.
          No Luck with M5.Axp.SetLcdVoltage(...);
          The value has to be from 0-255 anyway.
          At the backside they mentioned the backlight:
          "BL: ACP_LDO3"
          So this seems to the same as in Core2.
          • teastainT Offline
            teastain @erazor
            @erazor I have an "always on" project using Core Basic. I use
            M5.Lcd.setBrightness(75); //75 is high
            and
            M5.Lcd.setBrightness(10); //10 is low
            Works well, you can try different values to suit.
            -Terry
            P.S.
            My other application runs on a Core2 and I use:
            if (enable) {
            M5.Axp.SetLcdVoltage(2900); //3000 very bright
            } else {
            M5.Axp.SetLcdVoltage(2600); //2500 way too dark, 2600 very dim
            • E Offline
              erazor
              Well, yeah... but nothing works with the M5-TOUGH which should support it via the Axp.
                Hello @erazor
                have a look at the AXP192.cpp where SetLDOVoltage() is used to manipulate LDO3 (aka brightness). Use it like below in your code.
                M5.Axp.SetLDOVoltage(3,3000);
                • E Offline
                  erazor
                  @felmue said in M5-TOUGH / unable to change display brightness:
                  Hi Felmue!
                  That one works, thanks a lot!
                  Really confusing that there is a PWM backlight LED mentioned in the library which does not work. And that the usage of SetLcdVoltage is inconsistent between the Core2 and TOUGH.
                  On Core2 the LcdVoltage changes DCDC3 (@param number 0=DCDC1 / 1=DCDC2 / 2=DCDC3 ) which is connected to LCD_BL. For the TOUGH on the other hand DCDC3 is unused and they used the LDO3.
                  So maybe they should simply change the line SetDCVoltage(2, voltage); to M5.Axp.SetLDOVoltage(3,voltage); or maybe even better introduce a new function SetLCDBacklightVoltage(...) in their library.
                  Thanks to all for your hints.
