    Factory Test and Microphone example not compiling M5 Stick C Plus (latest version)
    M5 Stick/StickC
    1.8k
    • B
      bazman
      Line 438 in M5StickCPlus\examples\FactoryTest.ino and line 55 M5StickCPlus\examples\Micophone.ino has a compile error on the line marked ----> below
      i2s_pin_config_t pin_config;
      #if (ESP_IDF_VERSION > ESP_IDF_VERSION_VAL(4, 3, 0))
      --------> pin_config.mck_io_num = I2S_PIN_NO_CHANGE;
      #endif
      pin_config.bck_io_num = I2S_PIN_NO_CHANGE;
      The error is:
      C:\Projects\ArduinoSketchbooks\GPS-Mic-Test\GPS-Mic-Test.ino: In function 'bool InitI2SMicroPhone()':
      GPS-Mic-Test:438:16: error: 'struct i2s_pin_config_t' has no member named 'mck_io_num'; did you mean 'bck_io_num'?
      bck_io_num
      exit status 1
      • B
        bazman @bazman
        @bazman Fix is to delete the line! Both the microphone example and the factory test project then work.
