    STAMP CATM does not respond (Solved, HTML Get and Send Email)
    Modules
    5.7k
    • H
      HappyUser
      I have my STAMP CATM connected to my M5StickC : GND to GND , +5 Out to 5V, G36 to RX and G26 to TX.
      Then :
      Serial2.begin(115200, SERIAL_8N1, RXD2, TXD2);
      delay(300);
      Serial2.println("ATI\r\n");
      Read_Response(5000); // Serial2 read into Receive_buffer
      Serial.println(Receive_buffer);
      But when reading out the Serial2 I get no response at all.
      Any idea?
        have you got a sim in it?
        • H
          HappyUser
          Thank you for your reply
          SIM card is placed according to picture.
          In the mean time I have tried different scenarios with :
          //Serial1.begin(115200, SERIAL_8N1, RXD2, TXD2);
          Serial1.begin(115200, SERIAL_8N1, 26, 0);
          //Serial1.begin(115200, SERIAL_8N1, 0, 26);
          This is based on the following link in which also problems with Serial are mentioned : https://community.m5stack.com/topic/1521/serial2-on-m5stickc/5
          This link appears to provide working serial to serial communication: https://gist.github.com/dj1711572002/0ad8aa8aee618e5f2b7bfa719bc2b736
          But no luck for me.
          I hope anyone got this working.
          Regards
          • H
            HappyUser
            Well,
            Finally found it :
            This is works : Serial1.begin(115200, SERIAL_8N1, 0, 26); // SIM7080G
            and G26 connected to TX and G0 to RX.
            Now trying to get the modem responding to SIM7080G commands.
              I’ve got one on my desk but haven’t purchased a sim for it yet
              • H
                HappyUser @HappyUser
                @happyuser
                A few tips who want to start with this module:
                1] Remove PIN code, makes life much easier
                2] Download the application notes for this module. Both the complete AT instruction set and the note on HTTP application. This document provides clear instructions how to use HTTP, GET, POST etc
                3] I experienced ERROR response on SHCONF command. Googled around, saw numerous hits. It appears that switching off and on power does the trick for me. I did not see a reset AT instruction
                4] I got it all working with these instructions :
                Serial.println("Begin..");
                //pinMode(RXD2, INPUT);
                //pinMode(TXD2, OUTPUT);
                //showLog("Reset Module...");
                //SIM7020
                //DTU.Init(&Serial1,36, 26);
                //Serial1.begin(115200, SERIAL_8N1, 26, 0);
                delay(300);
                //Serial1.print("ATI\r\n");
                //Serial1.println("AT+CSQ\r\n");
                //Serial1.println("AT+IPR?\r\n");
                Serial1.print("ATZ\r\n");  // Reset to default
                delay(10);
                delay(500);
                Serial1.print("AT+IPR=115200\r\n");  // Reset to default
                delay(10);
                delay(500);
                Serial1.print("AT+CCLK?\r\n");  // Reset to default
                delay(10);
                delay(500);
                Serial1.print("AT+SHSSL=1,\"\"\r\n");  // Reset to default
                delay(10);
                delay(500);
                Serial1.print("AT+CFUN=1\r\n");  //
                delay(10);
                delay(500);
                Serial1.print("AT+CMGF=1\r\n");  // text mode
                delay(10);
                delay(500);
                // Om http te testen
                Serial1.print("AT+CFUN=0\r\n");  // Disable RF
                delay(10);
                delay(500);
                //Serial1.print("AT+CGDCONT=1,\"IP\",\"internet\",,0,0\r\n");  //
                Serial1.print("AT+CGDCONT=1,\"IP\",\"internet\"\r\n");  //
                delay(10);
                delay(500);
                Serial1.print("AT+CFUN=1\r\n");  // Enable RF
                delay(10);
                delay(500);
                Serial1.print("AT+CGATT?\r\n");  // Check PS Service
                delay(10);
                delay(500);
                Serial1.print("AT+CGNAPN\r\n");  // Query the APN service
                delay(10);
                delay(500);
                Serial1.print("AT+CNCFGN=0,1,\"internet\",,0,0\r\n");  // Before activation please
                delay(10);
                delay(500);
                Serial1.print("AT+CNACT=0,1\r\n");  // Activate
                delay(10);
                delay(500);
                Serial1.print("AT+CNACT?\r\n");  // Query the APN service
                delay(10);
                delay(500);
                Serial1.print("AT+SHCPARA\r\n");  //
                delay(10);
                delay(500);
                Serial1.print("AT+SHCONF=?\r\n");  //
                delay(10);
                delay(500);
                Serial1.print("AT+SHCONF?\r\n");  //
                delay(10);
                delay(500);
                // Serial1.print("AT+SHCONF="URL","https://api.thingspeak.com/update"\r\n"); // Query the APN service
                //Serial1.print("AT+SHCONF="URL","httpbin.org"\r\n"); // Query the APN service
                //Serial1.print("AT+SHCONF="URL","http://34.193.132.77"\r\n"); // Query the APN service
                //SIM7600_Error=1;
                //for (int i=0;i<10;i++)
                      //Serial1.print("AT+SHCONF=\"URL\",\"http://www.google.com\"\r\n");  // Query the APN service
                      Serial1.print("AT+SHCONF=\"URL\",\"http://www.httpbin.org\"\r\n");  // Query the APN service
                      delay(10);
                      delay(2000);
                   //   if (SIM7600_Error=0) {break;}
                Serial1.print("AT+SHCONF=\"BODYLEN\",1024\r\n");  //
                delay(10);
                delay(500);
                Serial1.print("AT+SHCONF=\"HEADERLEN\",350\r\n");  //
                delay(10);
                delay(500);
                Serial1.print("AT+SHCONN\r\n");  // Query the APN service
                delay(10);
                delay(500);
                Serial1.print("AT+SHSTATE?\r\n");  // Query the APN service
                delay(10);
                delay(500);
                Serial1.print("AT+SHCHEAD\r\n");  // Query the APN service
                delay(10);
                delay(500);
                Serial1.print("AT+SHAHEAD=\"User-Agent\",\"curl/7.47.0\"\r\n");  //
                delay(10);
                delay(500);
                Serial1.print("AT+SHAHEAD=\"Cache-control\",\"no-cache\"\r\n");  //
                delay(10);
                delay(500);
                Serial1.print("AT+SHAHEAD=\"Connection\",\"keep-alive\"\r\n");  //
                delay(10);
                delay(500);
                Serial1.print("AT+SHAHEAD=\"Accept\",\"*/*\"\r\n");  //
                delay(10);
                delay(500);
                Serial1.print("AT+SHREQ=\"/get?user=jack&password=123\",1\r\n");  //
                delay(10);
                delay(500);
                Serial1.print("AT+SHREAD=0,391\r\n");  //
                delay(10);
                delay(500);
                • H
                  HappyUser
                  Okay, Had a lot of <bad language> getting sending email working.
                  Than I realized that powering the module straight from the M5StickC appeared to causes glitches. I have placed a capacitor on top of the 5Volt to the module and now I am able to send emails also. For those that are interested, here is the code (with a lot of overhead no doubt, that works for me ):
                  delay(300);
                  delay(10);
                  Read_Response_OK(5000);
                  delay(500);
                  Serial1.print("AT+CREBOOT\r\n");  // Reset to default
                  delay(10);
                  delay(500);
                  Serial1.print("AT+CMEE=2\r\n"); // Verbose error printing ??
                  delay(10);
                  delay(500);
                  Serial1.print("AT+IPR=115200\r\n");  // SetTE-TAFixedLocalRate
                  delay(10);
                  delay(500);
                  Serial1.print("AT+CCLK?\r\n");  // Clock
                  delay(10);
                  delay(500);
                  // Upload a file
                  Serial1.print("AT+CFSINIT\r\n");  // Clock
                  delay(10);
                  delay(500);
                  String Command_Str;
                  Command_Str="AT+CFSWFILE=0,"0001.txt",0,";
                  Command_Str=Command_Str+FileSize;
                  Command_Str=Command_Str+",10000\r\n";
                  Serial.println(Command_Str);
                  Serial1.print(Command_Str);
                  delay(10);
                  delay(500);
                  for (int i=0;i<FileSize;i++) {Serial1.print(jpg_small[i]);}
                  Serial1.print("AT+CFSGFIS=0,\"0001.txt\"\r\n");  //
                  delay(10);
                  delay(500);
                  Serial1.print("AT+CPIN?\r\n");  // Ccheck SIM
                  delay(10);
                  delay(500);
                  Serial1.print("AT+CSQ\r\n");  // Check signal
                  delay(10);
                  delay(500);
                  Serial1.print("AT+CFUN=0\r\n");  // Set Phone Functionality isable RF
                  delay(10);
                  delay(500);
                  Serial1.print("AT+CGDCONT=1,\"IP\",\"internet\"\r\n");  //  Define PDP Context
                  delay(10);
                  delay(500);
                  Serial1.print("AT+CFUN=1\r\n");  // Set Phone Functionality Enable RF
                  delay(10);
                  delay(500);
                  Serial1.print("AT+CGATT?\r\n");  // Attach or detach from GPRS service
                  delay(10);
                  delay(500);
                  Serial1.print("AT+CGNAPN\r\n");  // Get Network APN in CAT-M or NB-IOT Query the APN service
                  delay(10);
                  delay(500);
                  delay(10);
                  delay(500);
                  Serial1.print("AT+CNACT=0,1\r\n");  // APP Network Active Activate
                  delay(10);
                  delay(500);
                  Serial1.print("AT+CNACT?\r\n");  // APP Network Active Activate Query the APN service
                  delay(10);
                  delay(500);
                  Serial1.print("AT+EMAILCID=0\r\n");  // Set parameters of email
                  delay(10);
                  delay(500);
                  Serial1.print("AT+EMAILTO=30\r\n");  // Set parameters of email time out
                  delay(10);
                  delay(500);
                  Serial1.print("AT+EMAILSSL=2,0,"email.cer","email.pem"\r\n"); // Set Encrypted mail
                  delay(10);
                  delay(500);
                  // https://randomnerdtutorials.com/esp32-send-email-smtp-server-arduino-ide/
                  Serial1.print("AT+SMTPSRV=\"smtp-mail.outlook.com\",587\r\n");  // Set SMTP server
                  delay(10);
                  delay(500);
                  //SMTP Password: (you need to use a Google App Password, not your Gmail password!)
                  //https://support.google.com/accounts/answer/185833
                  // https://www.hesk.com/knowledgebase/index.php?article=72
                  Serial1.print("AT+SMTPAUTH=1,\"my.email.com\",\"myApppassword\"\r\n");  // Set username and password
                  delay(10);
                  delay(500);
                  Serial1.print("AT+SMTPCS=\"ASCII\"\r\n");  // Set Email SSL function
                  delay(10);
                  delay(500);
                  Serial1.print("AT+EMAILSSL?\r\n");  // Read Email SSL function
                  delay(10);
                  delay(500);
                  Serial1.print("AT+EMAILSSL=2,0,\"\",\"\"\r\n");  // Set Email SSL function
                  delay(10);
                  delay(500);
                  delay(10);
                  delay(500);
                  Serial1.print("AT+SMTPFROM=\"my.email@outlook.com\",\"Fakename\"\r\n");  // Set username and password
                  delay(10);
                  delay(500);
                  Serial1.print("AT+SMTPRCPT=0,0,\"Sendto@mac.com\",\"john\"\r\n");  // Set recipient To:
                  delay(10);
                  delay(500);
                  Serial1.print("AT+SMTPSUB=\"Test4\"\r\n");  // Set recipient Bcc:
                  delay(10);
                  delay(500);
                  String Email_Body="This is a new Email";
                  int Body_size;
                  Body_size=Email_Body.length();
                  Serial.print("Body size is :");
                  Serial.println(Body_size);
                  Serial1.print("AT+SMTPBODY=19\r\n");  // Set recipient Bcc:
                  delay(10);
                  //Serial.println(Receive_buffer);
                  //delay(500);
                  Serial1.print(Email_Body);
                  //Serial1.print("\r\n");
                  delay(10);
                  delay(500);
                  char ccc;
                  Serial.println("AT+SMTPSEND");
                  Serial1.print("AT+SMTPSEND\r\n"); //
                  delay(10);
                  while (Serial1.available())
                  ccc=Serial1.read();
                  Serial.print(ccc);
                  Read_Response(5000); //Geen OK
                  delay(500);
                  Serial.println("And we are done");
                  while (1) {delay(300);}
                    Thanks for this, I haven't started on mine as still looking through IOT services
