    Displaying JPEG Images on M5StickC
    3 Posts 3 Posters 8.6k Views 1 Watching
    • o.coplestonO Offline
      o.copleston
      I'm in the process of constructing a WiFi based reverse camera for my car. I'm successfully sending a JPEG stream from an ESP32Cam to my M5StickC which I wish to display on the LCD. Looking at the M5Display library, half the code is essentially disabled, including the drawJpg() function which I need to use.
      I've tried uncommenting all of that and the prerequisite functions but have had no luck in displaying any images.
      Has anybody got a solution to displaying JPEGs?
      • B Offline
        boverby @o.copleston
        @o-copleston
        Don't know if you are still plugging away, but I was able to use another library from Bodmer. github TJpg_Decoder. I read a jpeg from a web server elsewhere , chunk it into an array and call
        #include <TJpg_Decoder.h>
        TJpgDec.drawJpg(0, 0, buffer, bufferlength );
        liberally copied from Web_Jpg example
          frexetat @boverby
          @boverby
          the link is dead would you mind sharing your code ?
          I am trying to stream to a m5stickc plus, what you did would be a good reference to look at ! thank you
