    core2_factory_test.ino error i2c_err_t
    Core 2
    3.4k
    • U
      u0xpsec
      Hello guys, I just got my M5Stack Core2 and im new to all this so bear with me here.
      Im working on a M1 MacBook Air, I installed Arduino IDE 2.0.3 M5Core2 Library 0.1.5 with all of the dependences it requires. I cloned the M5-ProductExampleCodes repo and am trying to compile core2_factory_test.ino but it keeps giving me an error. I already searched online for the same issue but i havent found anything. would anyone be able to give me a hand with this? Thanks in advance.
      this is the error im getting from the compiler:
      "/Users/u0xpsec/M5-ProductExampleCodes/Core/M5Core2/Arduino/Core2_Factory_test/ft6336_fw_updater.cpp: In function 'bool i2c_read(const uint8_t*, int, uint8_t*, int)':
      /Users/u0xpsec/M5-ProductExampleCodes/Core/M5Core2/Arduino/Core2_Factory_test/ft6336_fw_updater.cpp:44:9: error: 'i2c_err_t' has not been declared
      if (i2c_err_t::I2C_ERROR_CONTINUE != Wire1.writeTransmission(i2c_addr, const_cast<uint8_t*>(wrbuf), wrlen, false))
      /Users/u0xpsec/M5-ProductExampleCodes/Core/M5Core2/Arduino/Core2_Factory_test/ft6336_fw_updater.cpp:44:48: error: 'class TwoWire' has no member named 'writeTransmission'; did you mean 'beginTransmission'?
      beginTransmission
      /Users/u0xpsec/M5-ProductExampleCodes/Core/M5Core2/Arduino/Core2_Factory_test/ft6336_fw_updater.cpp:50:7: error: 'i2c_err_t' has not been declared
      if (i2c_err_t::I2C_ERROR_OK != Wire1.readTransmission(i2c_addr, rdbuf, rdlen, true))
      /Users/u0xpsec/M5-ProductExampleCodes/Core/M5Core2/Arduino/Core2_Factory_test/ft6336_fw_updater.cpp:50:40: error: 'class TwoWire' has no member named 'readTransmission'; did you mean 'endTransmission'?
      endTransmission
      /Users/u0xpsec/M5-ProductExampleCodes/Core/M5Core2/Arduino/Core2_Factory_test/ft6336_fw_updater.cpp: In function 'bool i2c_write(const uint8_t*, int)':
      /Users/u0xpsec/M5-ProductExampleCodes/Core/M5Core2/Arduino/Core2_Factory_test/ft6336_fw_updater.cpp:60:7: error: 'i2c_err_t' has not been declared
      if (i2c_err_t::I2C_ERROR_OK != Wire1.writeTransmission(i2c_addr, const_cast<uint8_t*>(buf), len, true))
      /Users/u0xpsec/M5-ProductExampleCodes/Core/M5Core2/Arduino/Core2_Factory_test/ft6336_fw_updater.cpp:60:40: error: 'class TwoWire' has no member named 'writeTransmission'; did you mean 'beginTransmission'?
      beginTransmission
      exit status 1
      Compilation error: 'i2c_err_t' has not been declared"
      • teastainT
        teastain
        • U
          u0xpsec
          @teastain i havent even tried to upload the one i have errors with, just verifying/compiling makes it errors. all ive done so far is use the m5burner to test different things.
            Hello guys
            @teastain : ft6336 != AT608A
            @u0xpsec : M5Core2 factory test code is broken for Arduino 2.x.x. You can either setup and compile with Arduino 1.x.x, try to fix the issue for Arduino 2.x.x. or as I did, comment out the not working part of the code which is not critical as is to update the ft6336 touch screen.
            • U
              u0xpsec
              thank you for the reply ill try comenting that piece of code and see if it compile.
