(Posibly) Bricked M5Paper
Hello.
I have M5Paper v1.0 and recently I started to play with it againg after I found out about UIFlow support. Sadly at one moment I and UI of M5Burner did not understant each other and I burden UIFlow firmware for Core into my M5Paper. The UIFlow works and I can connect to it via web app, but I can not overwrite it. M5Burner don't connect as well as Arduino IDE. Is there way to nuke whole ESP32 and burn in correct firmware? M5Paper now respond on 115200 baudrate but not even switching to that speed for writing helped.
Thanks. -
In M5Burner you use the Erase button to "Nuke" the existing firmware.
