    89 Posts 25 Posters 447.4k Views 10 Watching
    • Y Offline
      yashax @frittna
      @frittna Can you please be kind to help me to adapt your code to display the Forex market, the same way.
      Thank you so very much in advance.
        dssguy1
        Recently my ticker just went to 0.00e+00 for BTC price and no chart. It says "WS Disconnected" now. Did something in the data source change to break this awesome little ticker?
          dssguy1
          Forgot to mention, it also says "No JSON in response".
          • B Offline
            bucket62
            I am also getting the W.S disconnected and no JSON message. Is there a way to update the config file so that users can change the API? I think this may be a problem with the binance API
            • frittnaF Offline
              frittna
              maybe it could be geo-blocked because here from the EU for example it still works normally!
              please test:
              https://api.binance.com/api/v3/depth?symbol=BTCUSDT&limit=1000
              and
              https://api.binance.us/api/v3/depth?symbol=BTCUSDT&limit=1000
              If only the .us domain works for you i will update the code soon for an .us version.
              If you compile it yourself with arduino you have to modify the .com to .us - so change these two lines:
              const char restApiHost = "api.binance.us";
              and
              const char wsApiHost = "stream.binance.us";
                Hello @frittna
                FWIW: here in Switzerland both URLs work for me.
                • frittnaF Offline
                  frittna
                  i uploaded a version that uses binance.us.
                  Use the M5Burner in my Zip File on Github
                  • B Offline
                    bucket62 @frittna
                    @frittna
                    Thank you frittna! I am in the U.S. and will try that out today. I will report back if it works.
                    • B Offline
                      bucket62
                      Hi Frittna, thank you for your help. The Binance.US api fixed the problem and I am back up and running. Thank you!
                        dssguy1
                        Works perfect! THANKS!!! Now I can watch myself losing money again!
                        • frittnaF Offline
                          frittna @dssguy1
                          @dssguy1 said in Bitcoin / Multi Crypto Coin Ticker with 24 candlesticks chart:
                          Nice to hear :) Well, Yes, like the frog methapher .. he would jump out instantly if he gets into too hot water to not get burnt but if he is sitting in cold water which rises in temperature slowly until it is cooking he will probably stay until he gets rekt. Who knows, nobody. Zero or moon or -98% - all is possible - have a really good plan (thats very hard to almost impossible if not investing tons of time) or have a position which you are comfortable with and dont do much
                          • TariqWilliamsT Offline
                            TariqWilliams
                            I'm always looking for ways to stay updated on the crypto market and this seems like a great way to do it. I'm especially excited about the three buttons that you've included, as they make it even easier to use. I appreciate you sharing your work with the community, and I'm sure many of us will find it extremely useful. Plus, if you're looking to stay on top of the market, you should check out the list of top ten currencies in the world for 2022. That way, you can make sure that you're investing in the right ones. Thanks for taking the time to make this project and for making it available to the rest of us!
                            • Y Offline
                              yashax
                              • Y Offline
                                yashax
                                Or maybe adapt it for the stock market? Is that at all possible?
                                • frittnaF Offline
                                  frittna @yashax
                                  @yashax
                                  is't not easy to adapt because i use a data stream direct from the binace exchange api with binace pairs only. Don't know if there is a similiar data stream for forex etc. candles that can be used in the same way (json format every 2 seconds with open, high, low, close and volume)
                                  • Y Offline
                                    yashax
                                    @frittna said in Bitcoin / Multi Crypto Coin Ticker with 24 candlesticks chart:
                                    librar
                                    How do I instal all the libraries that are included in the Public/Libraries
                                    They are in their own directories.
                                    Can someone please be kind to point out exactly how to do this?
                                    Thank you in advance.
                                    • frittnaF Offline
                                      frittna
                                      you have to follow the guide in the readme.txt if you want to compile it in arduino to modify something in the code.
                                      download them all with Arduino -> library-manager - and watch for correct spelling and correct version numbers like in the readme given.
                                      or if you dont want to change the code then take the easy way without any coding and load it into the m5-stack core1(!) not 2 - i think no one runs it on a core version 2 m5-stack units because there would be some changings needed with library versions and code (resets all time and won't start correct atm)
                                      • Y Offline
                                        yashax
                                        Thank you so much. I installed all the libraries.
                                        I noticed that SHT3X.H file was not part of the "libraries" directories under main "Arduino" folder.
                                        I created a SHT3X directory under "libraries" and copied SHT3X.H into it. Not sure if it was correct or not. Without doing this, I was receiving SHT3X.H not found.
                                        When compiling, I am receiving the following errors:
                                        WARNINGL library timezone claims to run on air architecture(s) and may be incompatible with your current board which runs on esp32 architecthure(s).
                                        sketch\Crypto_Coin_Ticker.ino.cpp.o:(.literal.startup._GLOBAL__sub_I_ssid+0xe0): undefined reference to 'SHT3X::SHT3X(unsigned char)'
                                        sketch\Crypto_Coin_Ticker.ino.cpp.o:(.literal.Z16drawSensorValuesv+0x20): undefined reference to 'SHT3X::get()'
                                        Can you please point me in the right direction on what I am doing wrong?
                                        • frittnaF Offline
                                          frittna
                                          the files SHTX3.ccp and SHTX3.h are normally in the root directory where you have the .ino file of the program (the sketch folder - ctrl+k loads it)
                                          you see the structure on root directory on github aswell
                                          because of the "#include" in the code it will show like this
                                          regarding the compiler messages i quote myself:
                                          btw: the one warning from "timezone" concerning a possible wrong architecture type while compiling the code is ok.. does not matter<
                                          other messages in red about the SHT3X are ok too but not like your error, they will look like this picture and do not disturb compiling
                                          i hope you have noticed that there is a very simple and short way to load the code without compiling in arduino at all .. right..? (M5Burner - "the simple way..") but i guess you know and want to modify something for your purpose
                                            DannyE @frittna
                                            @frittna Amazing project, many thanks. using the tool it is very easy to load and configure. I am looking to make a similar data stream using train departure times but coding is not my stong point!
