    89 Posts 25 Posters 447.4k Views 10 Watching
    • frittnaF Offline
      frittna @yashax
      @yashax
      regarding TIME token - I see 4 different tokens with that name but none of it is listed on binance.
      An optional cycling function like you're asking was added in the last version i've released a month ago.
      Scroll up or go to the github source page.
      btw: do you have a core1 unit now?
      • Y Offline
        yashax @frittna
        @frittna Yes, picked up 2 Core 1’s with stands. ))
        Regarding TIME, so if it’s not listed on Binance, it won’t work?
        Thank you for all your help.
        J
        • frittnaF Offline
          frittna @yashax
          @yashax
          yes, thats correct since prize data comes from the binance api only, spot markets, no derivates
          • Y Offline
            yashax
            How can I change clock from 24hr to 12hr?
            Thank you
            • frittnaF Offline
              frittna @yashax
              you can check at line 500 in the code and simply change lines where is says "time(now)" to "timeFormat12(now)"
              this will work and will show time in am/pm mode and not in 24h mode.
              If you want to have a visualisation for am/pm too you would have to find free space first and draw something small with a the isAM() or isPM() function.
              • Y Offline
                yashax @frittna
                @frittna Thank you so much.
                What’s the while line on the chart?
                • frittnaF Offline
                  frittna @yashax
                  @yashax
                  the white line is the relative trading volume from the last 24 shown candles
                  • Y Offline
                    yashax @frittna
                    @frittna Can you please be kind to help me to adapt your code to display the Forex market, the same way.
                    Thank you so very much in advance.
                      dssguy1
                      Recently my ticker just went to 0.00e+00 for BTC price and no chart. It says "WS Disconnected" now. Did something in the data source change to break this awesome little ticker?
                        dssguy1
                        Forgot to mention, it also says "No JSON in response".
                        • B Offline
                          bucket62
                          I am also getting the W.S disconnected and no JSON message. Is there a way to update the config file so that users can change the API? I think this may be a problem with the binance API
                          • frittnaF Offline
                            frittna
                            maybe it could be geo-blocked because here from the EU for example it still works normally!
                            please test:
                            https://api.binance.com/api/v3/depth?symbol=BTCUSDT&limit=1000
                            and
                            https://api.binance.us/api/v3/depth?symbol=BTCUSDT&limit=1000
                            If only the .us domain works for you i will update the code soon for an .us version.
                            If you compile it yourself with arduino you have to modify the .com to .us - so change these two lines:
                            const char restApiHost = "api.binance.us";
                            and
                            const char wsApiHost = "stream.binance.us";
                            • felmueF Online
                              Hello @frittna
                              FWIW: here in Switzerland both URLs work for me.
                              • frittnaF Offline
                                frittna
                                i uploaded a version that uses binance.us.
                                Use the M5Burner in my Zip File on Github
                                • B Offline
                                  bucket62 @frittna
                                  @frittna
                                  Thank you frittna! I am in the U.S. and will try that out today. I will report back if it works.
                                  • B Offline
                                    bucket62
                                    Hi Frittna, thank you for your help. The Binance.US api fixed the problem and I am back up and running. Thank you!
                                      dssguy1
                                      Works perfect! THANKS!!! Now I can watch myself losing money again!
                                      • frittnaF Offline
                                        frittna @dssguy1
                                        @dssguy1 said in Bitcoin / Multi Crypto Coin Ticker with 24 candlesticks chart:
                                        Nice to hear :) Well, Yes, like the frog methapher .. he would jump out instantly if he gets into too hot water to not get burnt but if he is sitting in cold water which rises in temperature slowly until it is cooking he will probably stay until he gets rekt. Who knows, nobody. Zero or moon or -98% - all is possible - have a really good plan (thats very hard to almost impossible if not investing tons of time) or have a position which you are comfortable with and dont do much
                                        • TariqWilliamsT Offline
                                          TariqWilliams
                                          I'm always looking for ways to stay updated on the crypto market and this seems like a great way to do it. I'm especially excited about the three buttons that you've included, as they make it even easier to use. I appreciate you sharing your work with the community, and I'm sure many of us will find it extremely useful. Plus, if you're looking to stay on top of the market, you should check out the list of top ten currencies in the world for 2022. That way, you can make sure that you're investing in the right ones. Thanks for taking the time to make this project and for making it available to the rest of us!
                                          • Y Offline
                                            yashax
