    Is the Grove port on the M5Stack Basic Core digital or analog?
    General
    6.0k
    • W
      wwhite
      I'm trying to connect this Seeed Studio button but not having any luck https://www.seeedstudio.com/Grove-Button.html.
      Here is the code:
      #include <M5Stack.h>
      int last_value = 0;
      int cur_value = 0;
      M5.begin(); // Init M5Stack.
      M5.Power.begin(); // Init power.
      pinMode(21, INPUT); // set pin mode to input.
      M5.Lcd.setTextColor(YELLOW); // Set the font color to yellow.
      M5.Lcd.setTextSize(2); // Setting the Font size.
      M5.Lcd.setCursor(80, 0); // Set the cursor position to (80,0).
      M5.Lcd.println("Button example");
      M5.Lcd.setTextColor(WHITE);
      cur_value = digitalRead(21); // read the value of BUTTON.
      M5.Lcd.setCursor(80, 25);
      M5.Lcd.print("Button");
      M5.Lcd.setCursor(0, 45);
      M5.Lcd.print("Value: ");
      M5.Lcd.setCursor(0, 85);
      M5.Lcd.print("State: ");
      if (cur_value != last_value) {
      M5.Lcd.fillRect(85, 45, 75, 85, BLACK); // Draw a black rectangle 75 by 85 at (85,45).
      if (cur_value == 0) {
      M5.Lcd.setCursor(95, 45);
      M5.Lcd.print("0"); // display the status
      M5.Lcd.setCursor(95, 85);
      M5.Lcd.print("pre");
      } else {
      M5.Lcd.print("1"); // display the status
      M5.Lcd.print("rel");
      last_value = cur_value;
      Thanks in advance.
        The Red One?
        Its I2C/ digital
        • W
          wwhite
          Thanks ajb2k3. I have established that I have an I2C device at address 0x53. The device is a Seeed Studio101020054 Grove - 3-Axis Digital Accelerometer. Now how do I read a value from that address?
          Thanks again.
          • teastainT
            teastain @wwhite
            https://github.com/Seeed-Studio/Accelerometer_ADXL345
            This is all you need to get a demo running.
            -You will also have to install these libraries:
            #include <Wire.h>
            #include <ADXL345.h>
            • W
              wwhite
              Thanks #teastain that works!
              I simply changed ADXL345 accel(ADXL345_STD) to ADXL345 accel(ADXL345_ALT) in example code ReadXYZ.ino.
              Thanks again.
