    Newbie Question
    General
    2.7k
    • Z
      zappawaddawadda
      I have just bought MStick C Plus, Core 2, and a few more. Finding the learning curve crazier than I first thought. I can use M5Burner but none of the demos other than Factory Test work properly. They load and run but only occupy a small portion of the MStick C+ screen.
      What am I doing wrong?
      BTW...it would be gr8 to have a newbie section on this forum. The next issue I face is getting the Arduino IDE to run
      • teastainT
        teastain @zappawaddawadda
        @zappawaddawadda Hi! There is an excellent tutorial on the first page of the M5StickCPlus documents page here:
        https://docs.m5stack.com/en/core/m5stickc_plus
        This is for the older Arduino ver 1.8.19 and is the easiest to use, IMHO.
        You get close to "machine level code" with the IDE which also accidentally teaches you C and C++ as you go along.
        If you have any difficulty, post a reply here!
