PortA i2c unit not recognized in Core2 when stacked onto Servo2?
I am using ExtIO2 unit with Servo2 stacked beneath Core2, but the Extio2 module is not recognized (
"extio Connect Error"
I am using the newest Extio2 library on withextio.begin(&Wire, 32, 33, 0x45)
and beginningM5.begin(true,false,true,false,kMBusModeInput)
. This pins shouldn't be a conflict, as Servo2 is running by default on the internal buswire1.begin(21,22)
.The Extio2 is recognized instantly at portA when used without the Servo2.
Anyone has an idea what could cause this?
Hello @swiminthesky
I assume you are using an external power supply for the Servo2 module as suggested here. I also assume that the Servo2 module on its own works fine, correct?
Are there any errors in the debug output? Maybe I2C related.
Felix -
Thanks Felix @felmue,
external power is used. Servo2 example (on
Wire1.begin(21, 22);
) also works like a charm.I used both these M5 i2c scanners I2CScanInternalAndAllPorts and I2C_Tester, but no I2C devices are found.
But after removing Servo2 the device is instantly found correctly!
(Also: I used PaHub on PortA inbetween and Extio2 is also instantly found when Servo2 is not stacked)
(ext power is not used for the picture, the Bottom2 also didn't make a difference afaik) -
Hello @swiminthesky
hmm, not sure what is going on.
Maybe the Servo2 library still uses
Wire
somewhere internally?Could it be a mechanical problem?
BTW: my I2CScanInternalAndAllPorts is for M5Paper - I have not tested it on other M5Stack devices.
Felix -
Yes, it seems to be a hardware problem! I switched the Servo2 module and everything works perfectly and the i2c connections over port A runs without any interruptions. Thanks Felix @felmue and sorry for bothering!
Hello @swiminthesky
no worries. Thank you for reporting back. I am glad it now works for you.
