    M5Stack Paper I2C Doesn't work
    Cores
    5
    15
    18.7k
    • I
      ispybadguys
      I am trying to use the Paper and I can't get any of the ports to work. The code I am using in below. One strange thing in this code is if I comment out M5.begin() I see the internal i2C devices but if I include it I don't see any devices.
      #include <M5EPD.h>
      // I2C (internal) - SDA: 21, SCL: 22
      // I2C (external - Port A) - SDA: 25, SCL: 32
      #define PortA_SDA 25 // Port A
      #define PortA_SCL 32
      #define PortB_SDA 26 // Port B
      #define PortB_SCL 33
      #define PortC_SDA 18 // Port C
      #define PortC_SCL 19
      #define INTERNAL_SDA 21
      #define INTERNAL_SCL 22
      void setup()
      // M5.begin();
      Serial.begin(115200);
      Wire.begin(INTERNAL_SDA, INTERNAL_SCL);
      void loop()
      int address;
      int error;
      /********** Internal ********/
      Serial.println("Scanning internal I2C");
      for(address = 1; address < 127; address++)
      if(error == 0)
      Serial.printf("Internal Device Found %#04x\n",address);
      delay(10);
      Serial.println("Done Scanning internal I2C");
      delay(500);
      /********** PortA ********/
      Serial.println("Scanning external I2C (PortA)");
      Wire1.begin(PortA_SDA, PortA_SCL);
      Wire1.beginTransmission(address);
      error = Wire1.endTransmission();
      if(error == 0)
      Serial.printf("PORT-A Device Found %#04x\n",address);
      } else Serial.print("."); //Serial.printf("No Device Found PORT-A %#04x\n",address);
      delay(10);
      Serial.println("Done Scanning PortA I2C");
      delay(500);
      /********** PortB ********/
      Serial.println("Scanning external I2C (PortB)");
      // M5.begin();
      Wire1.begin(PortB_SDA, PortB_SCL);
      if(error == 0)
      Serial.printf("PORT-B Device Found %#04x\n",address);
      } else Serial.print("."); //Serial.printf("No Device Found PORT-B %#04x\n",address);
      delay(10);
      Serial.println("Done Scanning PortB I2C");
      delay(500);
      /********** PortC ********/
      Serial.println("Scanning external I2C (PortC)");
      // M5.begin();
      Wire1.begin(PortC_SDA, PortC_SCL);
      if(error == 0)
      Serial.printf("PORT-C Device Found %#04x\n",address);
      } else Serial.print("."); //Serial.printf("No Device Found PORT-C %#04x\n",address);
      delay(10);
      delay(5000);
        Hello @ispybadguys
        calling M5.begin() already takes care of Serial and Wire. I suggest you only call M5.begin() (which also initialises other M5Paper hardware) in setup().
        As for the I2C scanning on the three ports. The latest ESP32 Arduino framework doesn't allow to just call Wire1.begin() repeatedly with different GPIOs for SDA and SCL. If you look at the debug output you'll see this warning [ 41263][W][Wire.cpp:204] begin(): Bus already started in Master Mode. every time you try that in the loop().
        So when the scanning is done for one port you need to call Wire1.end() before calling Wire1.begin() again.
        • I
          ispybadguys
          Thanks. I'll try that. When I call M5.begin(); I get the following behavior.
          M5EPD initializing...OK
          continues forever.
          • I
            ispybadguys
            If I comment out the internal I2C section so I only have the PORT-A scan I get the following:
            ..............................................................................................................................Done Scanning PortA I2C
            It takes about one second for each address scanned. This is probably the default timeout.
            Kurt
              ajb2k3 @ispybadguys
              @ispybadguys What external devices have you tried connecting?
                Hello @ispybadguys
                are you saying that simply calling M5.begin() in setup(), e.g.
                #include <M5EPD.h>
                produces M5EPD initializing...OK over and over again?
                  Hello @ispybadguys
                  please find the I2C internal and all port scanner (which works for me) here.
                  • I
                    ispybadguys
                    Yes. I tested the very code you have here with just to include and M5.begin() and I get M5EPD initializing... followed by a 4 second pause and then the OK
                    • I
                      ispybadguys
                      Thanks for the code . For scanning the I2C. The code produces the following output:
                      I2C Scan - internal
                      .M5EPD initializing...OK
                      I2C Scan - internal
                      I2C Scan - internal
                        Hello @ispybadguys
                        that is very weird - I am stumped.
                        Have you tried to only scan the ports by commenting these two lines:
                        //  Serial.println("I2C Scan - internal");
                        //  scanI2C(i2cBus_Internal.wire, i2cBus_Internal.sda, i2cBus_Internal.scl);
                        BTW: I also get a 4 seconds delay before OK is printed out - so that should be fine.
                        • I
                          ispybadguys
                          Yes. I just tried that. I get the same behavior. I moved the script to a new Windows computer and installed the IDE there. I get
                          13:10:21.290 -> I2C Scan - Port A
                          13:10:21.290 -> .M5EPD initializing...OK
                          13:10:25.790 -> I2C Scan - Port A
                          I can actually scan the internal ports correctly if I don't call M5.begin(); and I just do a Serial.begin() and the wire commands.
                          BTW the boards.txt has an error in it for the M5-Paper and you cannot upload code from the Arduino IDE. I fixed that and I can upload ok now.
                          Kurt
                            Hello @ispybadguys
                            the debug output suggests that as soon as the I2C port scan starts (first dot) your M5Paper seems to reboot.
                            • Have you tried a different / shorter USB cable? Maybe the issue is power related?
                            • Does the touch example (requires internal I2C) work?
                            • I
                              ispybadguys
                              Yes. That looks to be the case that it crashed after one or two Wire1 commands. Usually one period is printed but sometimes two. Also the internal I2C does not work is I call M5.begin but it does if I just call Wire.begin.
                              • K
                                Koiru
                                I'm having exactly the same issue. Have you figured out what causes it?
                                  Morne
                                  @Koiru I have not found a solution but I have found a workaround.
                                  The culprit creating the constant reboots are the touchscreen, if I call the begin function without enabling the touchscreen I can get the unit to work instead of doing constant reboots.
                                  To initialize the unit without touchscreen, use the following arguments:
                                  M5.begin(false, true, true, true, true);
