M5Core2 version 2.0.5 Arduino update won't install on a Mac OSX?
Somehow the update creates two directories in /tmp causing this error 13 message:
(OS Monterey)Error: 13 INTERNAL: Cannot install platform:installing platform m5stack:esp32@2.0.5: searching package root dir: no unique root dir in archive, found '/Users/MacMarelli/Library/Arduino15/tmp/package-4036131626/2.0.5' and '/Users/MacMarelli/Library/Arduino15/tmp/package-4036131626/__MACOSX'
Can I manually control this update process?
Can I install this update manually by replacing the existing 2.0.5 or will this result in unexpected errors -
Have you installed Xcode and python 3 latest versions?
Have you installed the latest usb driver? -
It is an update, so why should I worry about XCode, Python and/or USB driver?
Sorry, forgot to mention that is for the Arduino IDE 2.0.0.
I'm not using Xcode and/or Python -
I went through the same problem. The folder __MACOSX is generated automatically by the MACOS when umcoressing the files. Then during the installation process I keeped watching inside the folder tmp and when the folder __MACOS was created I deleted it.
@fosouza Thanks!
It took some quick-clicking, but I got the 2.0.5 installed.
