Stamp C nonblocking led script?
Hello together,
using my Stamp C but cannot get the button led running without blocking.
anybody can point me to a sample for this?
would be great !Thx & cheers, K.
Hello @Knobsi
The RGB LED can use the neopixel Write instruction with Arduino ESP32 Version 2.0.4.
Arduino IDE Boards Manager
https://github.com/espressif/arduino-esp32/releases?fbclid=IwAR19R5_0Y1bW5DiYk4PBp7RAeFKjNrSo9YJZuHXmwNKY-dT7z_fYDKHzSoI
Improvements- Implemented a simple RGB driver via digitalWrite
- Implement simple RGB driver via digitalWrite; solving #6783 by @PilnyTomas in #6808
https://github.com/espressif/arduino-esp32/blob/master/cores/esp32/esp32-hal-rgb-led.h
void neopixelWrite(uint8_t pin, uint8_t red_val, uint8_t green_val, uint8_t blue_val);
:#define LED_PIN 2
neopixelWrite(LED_PIN,10,100,200); // GPIO,R,G,B
}void loop() {
You can make a new class , create a task to control blink or not, and color, with only one function call in you main code . I have done it, but is on vacation now, so cant share it.
With your input, this post could be even better đ
