    Crashes / exception with atomlite
    Micropython
    4.9k
      mm-uiflow
      Hey guys, i have used "try" around my i2c loop and mqtt to get the error and try to recover from it. how ever struggeling to fix it( i heard from an alternative mqtt library but i wanted to know if you guys have another idea)
      Here you see my grafana graph. Loop gets increased after every "readvalues loop function" (mqtt )
      After these about 3000 loops it resets.
      Here is the flow:
      And this( bottom of the read values function) :
      Serial console:
      [9362069] MQTTException -> Server close socket link
      reconnect start ...
      reconnect finish ...
      [9366820] MQTTException -> -110
      reconnect start ...
      [9371201] MQTTException -> -110
      reconnect start ...
      [9376101] MQTTException -> -110
      reconnect start ...
      [9380496] MQTTException -> -110
      reconnect start ...
      [9385483] MQTTException -> -110
      reconnect start ...
      [9389926] MQTTException -> -110
      reconnect start ...
      [9394818] MQTTException -> -110
      reconnect start ...
      [9399401] MQTTException -> -110
      reconnect start ...
      [9404361] MQTTException -> -110
      reconnect start ...
      [9408826] MQTTException -> -110
      reconnect start ...
      [9413730] MQTTException -> -110
      reconnect start ...
      [9418185] MQTTException -> -110
      reconnect start ...
      [9423081] MQTTException -> -110
      reconnect start ...
      [9427470] MQTTException -> -110
      reconnect start ...
      [9432469] MQTTException -> -110
      reconnect start ...
      [9437051] MQTTException -> -110
      reconnect start ...
      [9365685] MQTTException -> Server close socket link
      reconnect start ...
      i get -104 mqtt exception and -110. i dont get to except it and try to stop the mqtt, wait a sec and start again. The wifi signal is good and its 1 m to the AP on this Atom ( not like in the other thread)
        mm-uiflow
        i found out when i set mqtt's QoS to 0. i have loops over 20k and higher. So no exceptions anymore ( it was memory alloc exception before).
        i want to use QoS 1. QoS 1 sends a message with a packet id see code below.
        What is the max interger value of micropython / uiflow? It seems like its crashing near the packetid value "65000"
          mm-uiflow
          it fixed my problem with the crashes, but now i have no QoS 1
