    WiFi.setHostname("Name"); not working (Core Basic)
    5.9k
      Stoni99
      I don't get an error message from the compiler, but the new name doesn't appear in the router
      WiFi.mode(WIFI_STA);
      WiFi.disconnect(); //Turn off all wifi connections.
      delay(100);
      WiFi.setHostname("M5StackCoreZaehler");
      WiFi.begin(ssid, password);
      M5.Lcd.print("Call to " + String(ssid));
      M5.Lcd.print('.');
      delay(1000);
      M5.Lcd.println(" ");
      M5.Lcd.println(WiFi.localIP());
      M5.Lcd.print("Signalstearke: ");
      M5.Lcd.println(WiFi.RSSI());
      server.begin();
      delay(4000);
      M5.Lcd.clear();
        Hello @Stoni99
        looks like you need to call WiFi.config() before setting a new host name as well. Please see this article. (Note: not tested myself.)
          Stoni99
          Unfortunately this doesn't work for me. I am doing something wrong?
          String hostname = "newName";
          void initWiFi() {
          //WiFi.disconnect(); //Turn off all wifi connections.
          //delay(100);
          WiFi.config(INADDR_NONE, INADDR_NONE, INADDR_NONE, INADDR_NONE);
          WiFi.setHostname(hostname.c_str()); //define hostname (wifi.config muss davor stehen
          M5.Lcd.print('.');
          delay(1000);
          server.begin();
          delay(4000);
          M5.Lcd.clear();
            Hello @Stoni99
            have you tried to reboot your router? From above linked article:
            Important: you may need to restart your router for the changes to take effect.
              Stoni99
              Unfortunately, a restart doesn't help either. maybe it's because of my older router.
