    ATOM Lite Display not display in smallHd 503
    9 Posts 4 Posters 14.5k Views
      cepics
      Hi all,
      somebody knows ATOM Display Lite settings for display on SmallHD 503 monitor?
      best regards
        macsbug
        Hello @cepics
        SmallHD 503 : 1920 x 1080
        Arduino IDE
        #include <M5AtomDisplay.h>
        You can set the resolution (width, height) with the argument.
        If omitted, 1280, 720
        // M5AtomDisplay display(); // 1280 x 720
        M5AtomDisplay display(1920,1080,24); // 1920 x 1080 , 24bit
        // TOSHIBA REGZA 32BC3 32inch 1366x768
        // M5AtomDisplay display(1366,768); // 1366 x 768
        // M5AtomDisplay display(1920/2,1080/2,24);
        example
        // ( 480, 1920);(1920, 480);(1280, 720);(1024, 768);
        // ( 960, 540);( 800, 600);( 640, 480);( 640, 400);
        // ( 640, 360);( 512, 212);( 256, 192);( 320, 240);
        // ( 240, 320);( 200, 200);( 240, 135);( 135, 240);
        // ( 160, 160);( 160, 80);( 80, 160);( 80, 80);
        It may not be displayed correctly depending on the supported resolution of the display.
        It may be possible to display by setting the resolution (width, height) to be output to the display with arguments 3 and 4.
        You can also set the width and height magnification with arguments 5 and 6.
        If the enlarged resolution is less than the output resolution, there will be a gap around the screen.
        // M5AtomDisplay display ( 512, 384, 1280, 800, 2, 2 );
        // M5AtomDisplay display ( 683, 384, 1366, 768, 2, 2 );
        • The width magnification must be a number that is divisible by the width of the output resolution
        // ex: M5AtomDisplay display ( 400, 250, 1280, 800, 3, 3 );
        In this example, 1280 is not divisible by 3, so the horizontal magnification is changed to 2.
        Reference :
        M5GFX/docs/ATOMDisplay.md
        M5GFX/examples/
        https://github.com/m5stack/M5GFX
        Overview of internal processing of ATOM Display(ATOM Displayの内部処理概要)
        https://qiita.com/ciniml/items/30759f0083df5e07865f
        Panel_M5HDMI.hpp
        https://github.com/m5stack/M5GFX/blob/master/src/lgfx/v1/panel/Panel_M5HDMI.hpp#L117
        Exsample :
        void setup(void){
        display.init();
        display.setRotation(0); //0=normal/1=90deg/2=180deg/3=270deg/4~7=upside down
        display.setColorDepth(24); // 24bit per pixel color setting // Set the color depth
        display.startWrite();
        for (int y = 0; y < display.height(); ++y){
        for (int x = 0; x < display.width(); ++x){
        display.writePixel(x, y, display.color888(x, x+y, y));
        display.endWrite();
        for (int i = 0; i < 16; ++i){
        int x = rand() % display.width();
        int y = rand() % display.height();
        display.drawCircle(x, y, 16, rand());
        display.endWrite();
        void loop(void){
        static constexpr const char hello_str[] = "Hello ATOM Display !";
        display.setFont(&fonts::Orbitron_Light_32);
        for (int i = -display.textWidth(hello_str); i < display.width(); ++i){
        display.drawString(hello_str,i,(display.height()-display.fontHeight())>>1);
        display.endWrite();
          cepics
          @macsbug said in ATOM Lite Display not display in smallHd 503:
          1920/2,1080/2,24
          No way to display something on the 503.... I tried all configuration:
          when I connect hdmi cable to the 503, the monitor "feel" something (green led on and image settings in the "in settings page" of 503) but no image displayed.....
          the same cable works in other setup....
            cepics
            from SmallHD503 datasheet:
            HDMI Input Types
            YCC 4:2:2 @ 8 bits, 8/10/12 bit color in RGB & YCC 4:4:4: 1080p60, 1080p59.94, 1080p50, 1080p30, 1080p29.97 1080p25, 1080p24, 1080p23.98,1080i60, 1080i59.94, 1080i50, 1080i30, 1080i29.97, 1080i25, 720p120, 720p119.88, 720p100, 720p60, 720p59.94 , 720p50, 720p30, 720p29.97, 720p25, 720p24, 720p23.98, 480p120, 480p119.88, 480p60, 480p59.94, 576p100, 576p50, 480i240, 480i239.76, 480i120, 480i119.88, 480i60, 480i59.94, 480i30, 480i29.97, 480i24, 480i23.98, 576i200, 576i100, 576i50, 576i25
              HappyUser @cepics
              @cepics said in ATOM Lite Display not display in smallHd 503:
              I read that you are also struggling with this (5 inch?) display. I am facing the same issues with Waveshare 5inch display. Although I have the very strong feeling that the software on the M5AtomDisplay as shipped is different from the GitHub factory test. Have you been able to get things working?
                cepics
                no, still don't work!!
                yes 5 inches.......
                  Waveshare displays can be hit and miss. I have a 7.1" that will work sometimes with the display but not always and sometime wont work with other HDMI devices.
                    cepics
                    Hi all,
                    two days ago, I wanted to try the Atom lite display and smallhd 503U again and, after loading the test sketch (https://docs.m5stack.com/en/atom/atom_display),
                    #include <Arduino.h>
                    #include <vector>
                    M5AtomDisplay display;
                    void setup(void)
                      display.begin();
                    void loop(void)
                      display.fillScreen(RED);
                      delay(1000);
                      display.fillScreen(GREEN);
                      delay(1000);
                      display.fillScreen(BLUE);
                      delay(1000);
                    the SmallHD 503U monitor began to color.
                    I then created my code and worked on it for two days, visualizing the data coming from another atom through the ESPNOW protocol without problems..
                    while I was working on the TX code (ATOM LITE), suddenly the smallhd 503U stopped displaying the HDMI output of the ATOM lite Display RX
                    then the ritual tests began:
                    atom and cables, on a TV, work perfectly
                    503U and cables connected to the PC work perfectly
                    I switched from battery to an AC adapter for the monitor (20v 11,5 A)
                    I updated the 503U firmware to the latest available, 5.5.6. ( was 4.7.2 than 4.8.7)
                    I tried all 5 cables present at home and they all work between AtomDisplay and TV and between PC and 503U and they don't work between AtomDisplay and 503U
                    I tried various settings of M5AtomDisplay display() and display.setColorDepth()
                    M5AtomDisplay display(1080,720,24);
                    M5AtomDisplay display(1080,720,50);
                    M5AtomDisplay display(1080,720,60);
                    M5AtomDisplay display ( 640, 360, 60, 1980, 1080, 2, 2, 74250000 );
                    display.setColorDepth(8);
                    display.setColorDepth(10);
                    I couldn't figure out if the 503U is capable of"adaptive resolution scaling" and the green led on the monitor for input sensing it went back off like at the beginning of this long story
                    I can't figure out what's happening and I ordered some new hdmi cables..
                    ideas?
                    best regards
                    Mauro
                      cepics
                      Unfortunately, even with new cables, the problem persists ..
                      I tested my SmallHD 503U monitor with a RPI3 and it works
                      @macsbug what do you think?
                      best regards
