AXP192 library SetChargeCurrent in M5StickC but not in M5StickCPlus
I'm using M5StickCplus and BugC for my project.
We some how made a automatic charging system with a wireless pads.But charging time takes quite long, and I found "SetChargeCurrent" but only in M5StickC, not Plus.
Just moving library file doesn't work.
Is there any register reference?
or plan to get this SetChargeCurrent back?Thank you for reading.
Hello @kazokutchi
From below comment I assume M5Stack engineers decided to not include the
SetChargerCurrent()
function for M5StickCPlus.// Not recommend to set charge current > 100mA, since Battery is only 80mAh.
// more then 1C charge-rate may shorten battery life-span.That said, have you tired to only copy the function by itself into the corresponding AXP192.cpp file of the M5StickCPlus library?
