[fixed]atomlite 1.9.7 name 'wlan' isn't defined
 if i use the original network functions i get: Traceback (most recent call last):
 File "flow/m5cloud.py", line 82, in _exec_fun
 File "<string>", line 39, in <module>
 NameError: name 'wlan' isn't defined
 i want to check what ip adress etc is set.all original network functions dont work. Smart config the same
 Hello @mm-uiflow I've tried UiFlow firmware 1.9.7 and 1.9.8 and with below commands (copied from the Python tab in flow.m5stack.com) I can print IP address etc. from m5stack import * from m5ui import * from uiflow import * import network wlan = network.WLAN(network.STA_IF) print(wlan.ifconfig())Thanks
 @felmue said in atomlite 1.9.7 name 'wlan' isn't defined: wlan = network.WLAN(network.STA_IF)
 print(wlan.ifconfig())if i just use the python code like you it works. Maybe i should create a custom block for that
 wlan = network.WLAN(network.STA_IF) is  i didnt used create station interface because of that wlan wasnt defined!
