    Cannot use UIFlow with Atom Lite
    General
    13
    12.8k
      Hello @ahorner
      thank you for reporting back. I am glad to hear you've got it working.
      • A
        ahorner @felmue
        @felmue Hi Felix
        Unfortunately, I am back,
        It appears if I reset or unplug and plug back in (effective reset) the device, the issue comes back.
        The device will only work after an erase, burn and connect to UIFlow. Once connected, I can run as much as I like. Any disconnect appears to "kill" the device with the aformentioned python error on the COM Monitor until I do another erase, burn and connect etc,
        Thanks,
        Alex
          Hello @ahorner
          I am sorry to hear. Very strange indeed. Unfortunately I cannot reproduce this issue. Maybe somebody else has an idea about what might be going on?
          • A
            ahorner
            Bump on this one, anyone know what might be going on? Thanks!
            • W
              wsanders @ahorner
              @ahorner IIRC I received this error on an M5StickC Plus when the firmware version and UIFlow version did not match.
              • A
                ahorner @wsanders
                @wsanders Hi there, I am using the latest firmware with the latest UIFlow
                  slavs
                  I've been experiencing a similar issue with two recently purchased ATOM Lite devices. However I couldn't even connect at all with UI flow on version 1.9.5.
                  I've been using the vscode extension as I find it to work butter than using UI Flow Desktop and Web. But still need to flash the device constantly.
                  Although I can successfully download and run the code, I can't get it to run in App mode, I suspect the OP might have the same problem.
                  • A
                    ahorner @slavs
                    @slavs Hi there, to you and to everyone:
                    I contacted M5Stack support and have received a reply. This issue is a known firmware bug with the ATOM Lite.
                    They said:
                    Hi Alex,
                    Yes. We confirmed that's a bug. We will fix it in recently version.
                    Currently now, you can click 'reflash' button before downloading the firmware, which should work.
                      slavs @ahorner
                      @ahorner thanks for letting know!
                      • A
                        ahorner
                        It appears this bug is fixed, not in the firmware, but in the latest version of UIFlow!
