    Cannot use UIFlow with Atom Lite
    13 Posts 4 Posters 13.8k Views
      ahorner @felmue
      @felmue Hi Felix,
      A full erase and reburn, with a change of API key, has corrected the problem. Doh! How did I not already try this?!?!
      Many thanks,
      Alex
        Hello @ahorner
        thank you for reporting back. I am glad to hear you've got it working.
          ahorner @felmue
          @felmue Hi Felix
          Unfortunately, I am back,
          It appears if I reset or unplug and plug back in (effective reset) the device, the issue comes back.
          The device will only work after an erase, burn and connect to UIFlow. Once connected, I can run as much as I like. Any disconnect appears to "kill" the device with the aformentioned python error on the COM Monitor until I do another erase, burn and connect etc,
          Thanks,
          Alex
            Hello @ahorner
            I am sorry to hear. Very strange indeed. Unfortunately I cannot reproduce this issue. Maybe somebody else has an idea about what might be going on?
              ahorner
              Bump on this one, anyone know what might be going on? Thanks!
              • W Offline
                wsanders @ahorner
                @ahorner IIRC I received this error on an M5StickC Plus when the firmware version and UIFlow version did not match.
                  ahorner @wsanders
                  @wsanders Hi there, I am using the latest firmware with the latest UIFlow
                    slavs
                    I've been experiencing a similar issue with two recently purchased ATOM Lite devices. However I couldn't even connect at all with UI flow on version 1.9.5.
                    I've been using the vscode extension as I find it to work butter than using UI Flow Desktop and Web. But still need to flash the device constantly.
                    Although I can successfully download and run the code, I can't get it to run in App mode, I suspect the OP might have the same problem.
                      ahorner @slavs
                      @slavs Hi there, to you and to everyone:
                      I contacted M5Stack support and have received a reply. This issue is a known firmware bug with the ATOM Lite.
                      They said:
                      Hi Alex,
                      Yes. We confirmed that's a bug. We will fix it in recently version.
                      Currently now, you can click 'reflash' button before downloading the firmware, which should work.
                        slavs @ahorner
                        @ahorner thanks for letting know!
                          ahorner
                          It appears this bug is fixed, not in the firmware, but in the latest version of UIFlow!
