    Uploading .bin program via SD card to Core2
    Core 2
    5
    8.5k
    • PatP
      Pat
      With the Core GRAY i had the feature to upload compiled .bin program files via SD card with the LovyanLauncher and select from menu. Because the GRAY is no longer available i want to move to Core2. But i do not find a solution for uploading program with SD card. Sadly the LovyanLauncher is discontinued as seen here and will not be updated for Core2.
      Is there any other tool to do this with Core2? Thank you for any response.
      Regards Patrick
      • L
        Leo05
        Looking for SD updater too, did you find a solutions?
        • L
          Leo05
          I found this code (first message) that is working fine for me on Core2 : https://community.platformio.org/t/m5stack-sd-card-firmware-update/20883/4
            macsbug
            Hello @Pat
            Core 2 is also possible with M5Stack-SD-Updater.
            M5Stack-SD-Updater
            https://github.com/tobozo/M5Stack-SD-Updater/tree/master/examples
            Exsample
            1.M5Stack-SD-Menu -> Export cmpiled Binaly -> menu.bin(Rename) -> SD
            2.Applicasion ( add checkSDUpdater: M5Core2-SDLoader-Snippet.ino) = app.bin -> SD
            3.M5Unified -> SD UPDATE
            • D
              dave17
              Hi, I have tried to install the M5StackSDUpdater on my Core2 with no success, can you please point me to the good version that I should use for flashing and any modifications necessary for this model? Thanks
              Dave
