    Writing and re-writing text?
    Core 2
    7
    8.9k
    • D
      david-bethesda
      I'm trying to create a text area on the screen where I can write some text (like a sensor value) and then periodically replace this with new text somehow. I can't find anything about how to do common operations like this. How do I erase the prior value and replace it with the new value? thanks
        You can hold use a label to display a sensor value and place it inside a loop so that it will constantly check the sensors reading and update the value.
        • D
          david-bethesda
          Thanks @ajb2k3 but I'm writing this particular code in C++ / Arduino so I'm using M5.Lcd
          • A
            AgreeDK @david-bethesda
            @david-bethesda you select where to write the text, x & y, then make a function to first erase the area with fill rect and then write the new text at x,y
            • D
              david-bethesda @AgreeDK
              @agreedk thanks! I guess that means I have to figure out how tall a font is in pixels, and how wide the phrase is, ugh. Feels very imprecise and clunky.
                macsbug
                Hello @david-bethesda
                Use "backgroundcolor"
                setTextColor(uint16_t color, uint16_t backgroundcolor);
                m5-docs/docs/en/api/lcd.md
                https://github.com/m5stack/m5-docs/blob/master/docs/en/api/lcd.md
                #include <M5Stack.h>
                M5.Lcd.setTextSize(2);
                // Numerical Value
                M5.Lcd.setCursor(5, 10);
                M5.Lcd.setTextColor(TFT_WHITE, TFT_BLACK);
                M5.Lcd.println(123456.78);
                M5.Lcd.println(" "); // "........."
                M5.Lcd.println(1.41);
                // Stirng
                M5.Lcd.setCursor(5, 50);
                M5.Lcd.println("987654.32");
                M5.Lcd.println("3.14");
                If there is no background color
                If there is a background color
                • D
                  david-bethesda @macsbug
                  @macsbug Thank you!
