    Stamp C3 reset pin.
    Modules
    stampc3 reset
    4.4k
    • BramB
      Bram
      Does Stamp C3 have a RESET pin? (I know it has a reset button, but it the RESET signal broken out on the header?)
      The espressif ESP32-C3-DevKitM-1 has RESET on pin 7.
      I did see a pin ENABLE on the StampC3... is that the same as RESET? Or its inverse?
      Thanks.
      BramB 1 Reply Last reply Reply Quote 0
      • BramB
        Bram @Bram
        It appears that ENABLE is indeed the RESET pin. I use it to connect SPI OLED RESET signals, and that works.
