    M5StickC or M5StickC PLUS microphone basic example not working [Solved]
    M5 Stick/StickC
    13.0k
      miamifish
      Hi, I am new to the M5stickc eco system. Wanted to try some experiments with the built-in microphone. Tried to run the example provided with M5Stickc->Basic->Microphone. Compiles and runs. I can see "Mic Test" on tft. But it doesn't do anything past that. Interestingly the M5Stickc->Basic->FactoryTest is the only microphone example that works and shows the wave form on the tft screen. I have tried both M5stickc and M5stickcplus. Can someone please provide any thoughts on what I am doing wrong? Please see video of my test in this attached link.
      YouTube Link
        You will be lucky to get a response at the moment due to the Chinese New Year.
        @felmue do you have any experience with the Stick C mics and Arduino?
        Have you tried comparing the microphone code between the two? it could be that something has changed and the code has not been updated.
          Hello guys
          I quickly had a look, but I couldn't spot the reason why the example doesn't work. Sorry.
          But since the factory test code works maybe you could try to extract the necessary microphone code from there?
          Edit: Just had another look using M5StickCPlus and the fix is quite easy. The gain factor needs to be upped to 30 (from 3) like this:
          #define GAIN_FACTOR 30
          and if you compile for arduino-esp32 version 2.x.x you also need to add this line:
          pin_config.mck_io_num = GPIO_NUM_0;
          to the pin config.
            miamifish
            Thank you Felix & ajb2k3! I tried to run it using the above changes and the example runs so well on M5stickc Plus. Is it possible to print the values using the Arduino IDE's serial plotter? I tried it like this, but it is not a clean wave ....!! There seems to be an offset in the signal? Thank you so much for saving the day!
              miamifish
              Sorry here is print code -
                ajb2k3 @felmue
                @felmue said in M5StickC or M5StickC PLUS microphone basic example not working:
                Hello guys
                to the pin config.
                Thanks @felmue I thought you may be able to solve this one and give the solutions.
                  Hello @miamifish
                  w/o trying it myself one thing that seems wrong to me is the fact that in every loop about READ_LEN (=512) samples are read from the microphone but at the same time you plot about 1000 samples...
                  M 2 Replies Last reply Reply Quote 0
                    miamifish @felmue
                      miamifish @miamifish
                        miamifish @felmue
                        Thank you to @felmue . The original issue I posted was resolved. We can close this post for basic microphone example works just fine after @felmue's suggestions. I will open a separate thread for the issue with regards to microphone offset in M5stickcPlus.
