    ENV III M5StickC-Plus SHT3X issues
    4 Posts 3 Posters 5.8k Views
      risingmoon
      I bought both the M5StickC Plus and ENV III Hat from digikey, but I have not been able to get temperature from SHT3X in Arduino IDE. I keep getting Wire.endTransmission() return value of for NACK. How do I fix/debug this or is this HAT broken?
      #include <M5Unified.h>
      #include <Wire.h>
        Serial.begin(115200);
        Wire.begin();
        // Start I2C Transmission
        Wire.beginTransmission(0x44);
        // Send measurement command
        Wire.write(0x2C);
        Wire.write(0x06);
        // Stop I2C transmission
        int result = Wire.endTransmission();
        if (result != 0) {
          Serial.println("Failed");
          Serial.println(result);
        delay(5000);
        Hello @risingmoon
        try Wire.begin(0,26);. (Note: Information taken from this example).
        If that doesn't help maybe try with UIFlow to figure out whether there is a hardware issue.
        • robskiR Offline
          robski
          @risingmoon have a look here
          https://github.com/m5stack/UNIT_ENV/blob/master/examples/UNIT_ENV_III/UNIT_ENV_III.ino
            risingmoon @felmue
            @felmue This fixed the issue! Thanks. I found that this was the issue. It was using Wire.begin() instead of Wire.begin(0,26)
