    problems to star my m5stack core 2
    SOFTWARE
    12
    16.5k
      magnetor
      Hi everyone, I just received the m5stack core 2 and after downloading the drivers, burner, uflow and everything I've seen on the network, I can't connect the device with burnner and uflow, i try to check the COM and try again but I see that the bluetooth and usbmodem appear but not the COM. I'm new to all of this and I'm pretty lost. After searching a lot I have seen that there is a menu on the device where you can configure an activate the usb port by pressing the power button for 5 seconds but .... no matter how much I do, I am not able to access it. I imagine that once that port is activated, I will be able to connect the device to the m5burnner and to uflow. Thank you
        have you shut your computer down and restarted it since installing drivers?
          magnetor
          @ajb2k3 hello yes, I have restarted the computer and everything is the same. 0_1632247057969_1.jpg
          i working with mac os high sierra 10.13
            It's not a usbmodem, that why it fails.
            It should appear as tty.SLAB_USBtoUART
              magnetor
              I already know and download the Usbtouart drivers but the same message continues to appear. I have written here because after watching tutorials and looking at the whole web I am not able to show usbtouart or COM in m5burnner ... thanks for your help
                magnetor
                @ajb2k3 SiLabsUSBDriver.kext is installed in library / extensions. I open m5burnner and connect the usb cable and turn on the m5stack and in COM: only these options appear
                  Mates28 @magnetor
                  @magnetor And don't you happen to have a macbook with an M1 chip?
                  • P
                    PiriX
                    Restart the Mac... after that plug the USB-C cable and the M5stack... that works for me
                      magnetor @Mates28
                      @mates28 i have a Mac mini 2012
                        I'm running a MBP 2012 Catalina
                          Delete the driver, shutdown the Mac fully, total power down (not log out or restart)
                          Turn on Mac install the driver the immediately fully power off the Mac again.
                          Power back up and try again.
                          The drivers are very finicky
                          works with OSX 10.14 but 10.15 is finicky again.
                            magnetor @ajb2k3
                            @ajb2k3 I just followed your steps and everything is the same ... i have OSX 10.13
