Tip and a minor Bug
Created a custom block. Added it to my code and it works.
Closed the page and re-opened my program but it is incomplete.
Loading stops when it reaches the custom blockWhat it means is the custom block file needs to be loaded before loading your program file.
I suggest this is added to the help here: https://docs.m5stack.com/en/uiflow/blockly_custom?id=using-program-block
The User Manager link in the custom block section goes to a dead link: https://docs.m5stack.com/en/related_documents/blockly_custom
It should go to https://docs.m5stack.com/en/uiflow/blockly_custom
Thank you feedback, we will add this help to the docs. also, could you tell me where did you get this old link? we wanna update it.
@m5stack The link was in the Flow UI.
The User Manual Button under the Create and Open file buttons.
