    want to power off m5stickC from code
    14.5k
    • P
      pattiuak
      I try these command non of them work.
      • M5.powerOFF();
        when compile i get result "'class M5StickC' has no member named 'powerOFF'"
      • M5.Axp.halt();
        when compile i get result "'class AXP192' has no member named 'halt'"
      • M5.Axp.SetSleep();
        program still running and wifi still on. battery will die in a few hour.
      • M5.Axp.DeepSleep();
        this seem to work but when I press power/reset bnt my program not start it just on the LCD with black color.
      Please help me.
      Thank You.
        What version of the librarys are you using?
        Have you checked arduino for updates.
        • P
          pattiuak @ajb2k3
          @ajb2k3 I using arduino version 1.8.9 (windows store 1.8.21 ) and m5stickC library 0.1.0.
            ajb2k3 @pattiuak
            @pattiuak What M5Stack Core library have you installed?
            • P
              pattiuak @ajb2k3
              @ajb2k3 It is m5stack library V 0.2.9
              • T
                tom8787
                In case anyone else is looking for the real PowerOff (and NOT deep sleep or any other sleep method), the command to use is
                M5.Axp.PowerOff();
                (mind the capitals)
                After this command you have to power your M5Stick manually by pressing the power button, but it works as a charm.
