    UIFlow 1.8.0
    31 Posts 11 Posters 92.7k Views 2 Watching
      John7
      Workaround to load old m5f files:
      Open a m5f in a text editor, save-as with a new name, and insert the below after
      "Blockly.Remotes":[],
      in the end of the file:
      "Blockly.RemotePlus":[{"createTime":1625241945254,"name":"M5Remote","dragAndDrop":false,"resizable":false,"color":"#fff","bgColor":"#0080FF","type":"title","id":"__title"}],
      U 1 Reply Last reply Reply Quote 1
      • OyczEO Offline
        OyczE @felmue
        @felmue said in UIFlow 1.8.0:
        Hello @m5stack
        thank you for the new version. I've tried the REMOTE+ but when I scan the QR code with my phone the browser returns a 404 - not found - error.
        Have you guys actually tested this stuff???
        In addition m5f files saved with UIFlow 1.7.8 no longer load with UIFlow 1.8.0. And yes, I am using Chrome and yes, I've cleared the cache.
        Looks like yet another regression. I must assume you still don't do any regression tests at all, or do you?
        Please fix.
        Its working for me. From uiflow and from core2 screen.
        0_1625252821268_Screenshot_20210702-210501_QR & Barcode Scanner.jpg 0_1625252828626_Screenshot_20210702-210425_Chrome.jpg
        • OyczEO Offline
          OyczE
          Bug#2 Remote+ missing variable in Button
          • U Offline
            UKTechguy @John7
            @john7 said in UIFlow 1.8.0:
            Thanks for the tip. That sorted it for me. Shame M5STack don't perform better quality control.
              Hello @Mati
              thank you very much for letting us know. I've just retried REMOTE+ myself and this time it worked. Either something went wrong the first time or maybe M5Stack fixed something already.
              • OyczEO Offline
                OyczE
                @m5stack just a one small suggestion, maybe development sprint or deployment should be done at monday then we are not losing weekend to be frustration.
                ajb2k3A 1 Reply Last reply Reply Quote 3
                  ajb2k3 @OyczE
                  @mati
                  @mati said in UIFlow 1.8.0:
                  This I wholeheartedly agree with!
                    anvalin
                    • m5stackM Offline
                      m5stack @John7
                      @john7 thank you feedback. we already fixed the issues. pls try again.
                      • m5stackM Offline
                        m5stack @OyczE
                        @mati actually that just a button. this function just like a callback, each time you press it, the function exec one time. so it can without the variable.
                          Hello @m5stack
                          thank you for letting us know. I appreciate it.
                          And yes, I can confirm that I can load previously saved m5f files into UIFlow 1.8.0 again.
                          • OyczEO Offline
                            OyczE
                            Hello @m5stack
                            #1
                            looks like new error popup in combination of Atom Lite and OLED 1.3'' module not only Env2 make error as well.
                            Simple remove 'from m5stack_ui import *' fix the problem
                            #2
                            Plus AtomLora DUT error ..
                            File "flow/m5cloud.py", line 82, in _exec_fun
                            File "<string>", line 3, in <module>
                            ImportError: no module named 'base.DTU_LoRAWAN'
                            #3
                            LoraWan868 + Core2
                            'module' object has no attribute 'LORAWAN'
                            Do we have any LoraWan support in 1.8.0 ?!
                            Regards
                            Mati
                              deathvedar
                              We tried to run the LoRaWAN 868 Unit with absolut no luck.
                              If i select it in the UIFlow event the frequency mask is empty while the mask of a 433 unit is pre filled.
                              please, please fix this ASAP!
                              • OyczEO Offline
                                OyczE
                                @m5stack could we get reply about uiflow support for lorawan ?
                                • m5stackM Offline
                                  m5stack @OyczE
                                  @mati you could try 0001 for the mask code
                                  • m5stackM Offline
                                    m5stack @OyczE
                                    @mati did you open more than two UIFlow web pages? if you open two pages in the same browser and use different hardware. that would have some conflict. so I think you just need to open a new browser. it will work fine.
                                    OyczEO 2 Replies Last reply Reply Quote 0
                                    • OyczEO Offline
                                      OyczE @m5stack
                                      @m5stack indeed it was two tabs !
                                      Let me check this, thx for a hint.
                                        tnkmasayuki
                                        I can't stop the sound.
                                        UIFlow1.8.0 + M5StickC Plus
                                          stefanj9
                                          Wher can I find version 1.8.0?
                                          • OyczEO Offline
                                            OyczE @stefanj9
