    UIFlow 1.8.0
    31 Posts 11 Posters 94.2k Views 2 Watching
      Hello @m5stack
      thank you for the new version. I've tried the REMOTE+ but when I scan the QR code with my phone the browser returns a 404 - not found - error.
      Have you guys actually tested this stuff???
      In addition m5f files saved with UIFlow 1.7.8 no longer load with UIFlow 1.8.0. And yes, I am using Chrome and yes, I've cleared the cache.
      Looks like yet another regression. I must assume you still don't do any regression tests at all, or do you?
      Please fix.
      OyczEO 2 Replies Last reply Reply Quote 1
      • OyczEO Offline
        OyczE @felmue
        @felmue community is making regression =]
          John7
          Yes, This release is a total disaster. I can't load my old projects.
          @m5stack please fix it
          • OyczEO Offline
            OyczE
            bug#1
            Hide gui in Chrome
            after Hide / Show i have to clean browser cache to see any block's ...
              John7
              Workaround to load old m5f files:
              Open a m5f in a text editor, save-as with a new name, and insert the below after
              "Blockly.Remotes":[],
              in the end of the file:
              "Blockly.RemotePlus":[{"createTime":1625241945254,"name":"M5Remote","dragAndDrop":false,"resizable":false,"color":"#fff","bgColor":"#0080FF","type":"title","id":"__title"}],
              U 1 Reply Last reply Reply Quote 1
              • OyczEO Offline
                OyczE @felmue
                @felmue said in UIFlow 1.8.0:
                Hello @m5stack
                Please fix.
                Its working for me. From uiflow and from core2 screen.
                0_1625252821268_Screenshot_20210702-210501_QR & Barcode Scanner.jpg 0_1625252828626_Screenshot_20210702-210425_Chrome.jpg
                • OyczEO Offline
                  OyczE
                  Bug#2 Remote+ missing variable in Button
                  • U Offline
                    UKTechguy @John7
                    @john7 said in UIFlow 1.8.0:
                    Thanks for the tip. That sorted it for me. Shame M5STack don't perform better quality control.
                      Hello @Mati
                      thank you very much for letting us know. I've just retried REMOTE+ myself and this time it worked. Either something went wrong the first time or maybe M5Stack fixed something already.
                      • OyczEO Offline
                        OyczE
                        @m5stack just a one small suggestion, maybe development sprint or deployment should be done at monday then we are not losing weekend to be frustration.
                        ajb2k3A 1 Reply Last reply Reply Quote 3
                          ajb2k3 @OyczE
                          @mati
                          @mati said in UIFlow 1.8.0:
                          This I wholeheartedly agree with!
                            anvalin
                            • m5stackM Online
                              m5stack @John7
                              @john7 thank you feedback. we already fixed the issues. pls try again.
                              • m5stackM Online
                                m5stack @OyczE
                                @mati actually that just a button. this function just like a callback, each time you press it, the function exec one time. so it can without the variable.
                                  Hello @m5stack
                                  thank you for letting us know. I appreciate it.
                                  And yes, I can confirm that I can load previously saved m5f files into UIFlow 1.8.0 again.
                                  • OyczEO Offline
                                    OyczE
                                    Hello @m5stack
                                    #1
                                    looks like new error popup in combination of Atom Lite and OLED 1.3'' module not only Env2 make error as well.
                                    Simple remove 'from m5stack_ui import *' fix the problem
                                    #2
                                    Plus AtomLora DUT error ..
                                    File "flow/m5cloud.py", line 82, in _exec_fun
                                    File "<string>", line 3, in <module>
                                    ImportError: no module named 'base.DTU_LoRAWAN'
                                    #3
                                    LoraWan868 + Core2
                                    'module' object has no attribute 'LORAWAN'
                                    Do we have any LoraWan support in 1.8.0 ?!
                                    Regards
                                    Mati
                                      deathvedar
                                      We tried to run the LoRaWAN 868 Unit with absolut no luck.
                                      If i select it in the UIFlow event the frequency mask is empty while the mask of a 433 unit is pre filled.
                                      please, please fix this ASAP!
                                      • OyczEO Offline
                                        OyczE
                                        @m5stack could we get reply about uiflow support for lorawan ?
                                        • m5stackM Online
                                          m5stack @OyczE
                                          @mati you could try 0001 for the mask code
                                          • m5stackM Online
                                            m5stack @OyczE
                                            @mati did you open more than two UIFlow web pages? if you open two pages in the same browser and use different hardware. that would have some conflict. so I think you just need to open a new browser. it will work fine.
                                            OyczEO 2 Replies Last reply Reply Quote 0
