    Not so good wifi signal strength
    6 Posts 3 Posters 10.5k Views
      sheepDog
      I bought two "M5Stack Core2 ESP32 IoT Development Kit for AWS IoT EduKit" and two "M5Stack Core2 ESP32 IoT Development Kit".
      Today I noticed that the AWS version did not receive the wifi as well. Both AWS version didn't work at my desk, but both non-AWS worked fine.
      I got the errors at startup:
      Wifi missing. Status=6
      I (7634) wifi:new:<11,0>, old:<1,0>, ap:<255,255>, sta:<11,0>, prof:1
      I (7634) wifi:state: init -> auth (b0)
      I (8634) wifi:state: auth -> init (200)
      I (8644) wifi:new:<11,0>, old:<11,0>, ap:<255,255>, sta:<11,0>, prof:1
      I (8764) wifi:new:<11,0>, old:<11,0>, ap:<255,255>, sta:<11,0>, prof:1
      I (8764) wifi:state: init -> auth (b0)
      I (9764) wifi:state: auth -> init (200)
      I (9764) wifi:new:<11,0>, old:<11,0>, ap:<255,255>, sta:<11,0>, prof:1
      I (9894) wifi:new:<11,0>, old:<11,0>, ap:<255,255>, sta:<11,0>, prof:1
      I (9894) wifi:state: init -> auth (b0)
      If I go two meters nearer to the AP both AWS worked fine, too.
      Have anyone an idea what I can you do (without that I go closer to the AP) ?
      • m5stackM Offline
        @sheepdog said in Not so good wifi signal strength:
        You can try. . . Change the transmit power of your AP
          sheepDog
          @m5stack thank you for your answer.
          This solution is just as trival as to go closer to the router. Unfortunately I cann't go closer and I cann't increase the transmit power. Can I connect an antenne to the "M5Stack Core2 ESP32 IoT Development Kit for AWS IoT EduKit"?
          • m5stackM Offline
            m5stack @sheepDog
            @sheepdog It will be more troublesome, you need to disassemble the original antenna, and then solder the new one
            • felmueF Online
              Hello @sheepDog
              to me it looks like both, the regular M5Core2 and the AWS version, are using identical hardware / same board revision - at least the ones I have do.
              The difference is in the M5GO2 bottom: the AWS M5GO2 bottom adds the secure element.
              That said, have you tried the AWS version w/o the AWS M5GO2 bottom attached?
                sheepDog @felmue
                Hello @felmue,
                you are right, the top of M5Core2 and the AWS are identical. But the bottom is the challenge: The ground of the AWS shields the antenna. -> Yes, I tried the AWS version without the AWS M5GO2 bottom attached.
                I tried this too:
                • Insert a prototyp board between AWS-top and AWS-bottom. It improves the field strength a little bit.
                • Insert a small silver wire in the prototyp board at the antenna of the AWS-top. So I almost reach the regular field strength.
