<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Not so good wifi signal strength]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I bought two "M5Stack Core2 ESP32 IoT Development Kit for AWS IoT EduKit" and two "M5Stack Core2 ESP32 IoT Development Kit".</p>
<p dir="auto">Today I noticed that the AWS version did not receive the wifi as well. Both AWS version didn't work at my desk, but both non-AWS worked fine.</p>
<p dir="auto">I got the errors at startup:</p>
<pre><code>Wifi missing. Status=6
I (7634) wifi:new:&lt;11,0&gt;, old:&lt;1,0&gt;, ap:&lt;255,255&gt;, sta:&lt;11,0&gt;, prof:1
I (7634) wifi:state: init -&gt; auth (b0)
I (8634) wifi:state: auth -&gt; init (200)
I (8644) wifi:new:&lt;11,0&gt;, old:&lt;11,0&gt;, ap:&lt;255,255&gt;, sta:&lt;11,0&gt;, prof:1
I (8764) wifi:new:&lt;11,0&gt;, old:&lt;11,0&gt;, ap:&lt;255,255&gt;, sta:&lt;11,0&gt;, prof:1
I (8764) wifi:state: init -&gt; auth (b0)
I (9764) wifi:state: auth -&gt; init (200)
I (9764) wifi:new:&lt;11,0&gt;, old:&lt;11,0&gt;, ap:&lt;255,255&gt;, sta:&lt;11,0&gt;, prof:1
I (9894) wifi:new:&lt;11,0&gt;, old:&lt;11,0&gt;, ap:&lt;255,255&gt;, sta:&lt;11,0&gt;, prof:1
I (9894) wifi:state: init -&gt; auth (b0)
<p dir="auto">If I go two meters nearer to the AP both AWS worked fine, too.</p>
<p dir="auto">Have anyone an idea what I can you do (without that I go closer to the AP) ?</p>
]]></description><link>https://community.m5stack.com/topic/3349/not-so-good-wifi-signal-strength</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Apr 2026 07:33:51 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3349.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 06 Jun 2021 15:39:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Not so good wifi signal strength on Thu, 10 Jun 2021 10:37:55 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/4037">@felmue</a>,</p>
<p dir="auto">you are right, the top of M5Core2 and the AWS are identical. But the bottom is the challenge: The ground of the AWS shields the antenna. -&gt; Yes, I tried the AWS version without the AWS M5GO2 bottom attached.</p>
<p dir="auto">I tried this too:</p>
<li>Insert a prototyp board between AWS-top and AWS-bottom. It improves the field strength a little bit.</li>
<li>Insert a small silver wire in the prototyp board at the antenna of the AWS-top.  So I almost reach the regular field strength.</li>
]]></description><link>https://community.m5stack.com/post/14070</link><guid isPermaLink="true">https://community.m5stack.com/post/14070</guid><dc:creator><![CDATA[sheepDog]]></dc:creator><pubDate>Thu, 10 Jun 2021 10:37:55 GMT</pubDate></item><item><title><![CDATA[Reply to Not so good wifi signal strength on Thu, 10 Jun 2021 07:02:05 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/88">@sheepDog</a></p>
<p dir="auto">to me it looks like both, the regular M5Core2 and the AWS version, are using identical hardware / same board revision - at least the ones I have do.</p>
<p dir="auto">The difference is in the M5GO2 bottom: the AWS M5GO2 bottom adds the secure element.</p>
<p dir="auto">That said, have you tried the AWS version w/o the AWS M5GO2 bottom attached?</p>
]]></description><link>https://community.m5stack.com/post/14067</link><guid isPermaLink="true">https://community.m5stack.com/post/14067</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 10 Jun 2021 07:02:05 GMT</pubDate></item><item><title><![CDATA[Reply to Not so good wifi signal strength on Thu, 10 Jun 2021 01:41:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/88">@sheepdog</a> It will be more troublesome, you need to disassemble the original antenna, and then solder the new one</p>
]]></description><link>https://community.m5stack.com/post/14064</link><guid isPermaLink="true">https://community.m5stack.com/post/14064</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Thu, 10 Jun 2021 01:41:31 GMT</pubDate></item><item><title><![CDATA[Reply to Not so good wifi signal strength on Tue, 08 Jun 2021 12:35:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/1">@m5stack</a> thank you for your answer.</p>
<p dir="auto">This solution is just as trival as to go closer to the router. Unfortunately I cann't go closer and I cann't increase the transmit power. Can I connect an antenne to the  "M5Stack Core2 ESP32 IoT Development Kit for AWS IoT EduKit"?</p>
]]></description><link>https://community.m5stack.com/post/14036</link><guid isPermaLink="true">https://community.m5stack.com/post/14036</guid><dc:creator><![CDATA[sheepDog]]></dc:creator><pubDate>Tue, 08 Jun 2021 12:35:20 GMT</pubDate></item><item><title><![CDATA[Reply to Not so good wifi signal strength on Tue, 08 Jun 2021 10:39:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/88">@sheepdog</a> said in <a href="/post/14016">Not so good wifi signal strength</a>:</p>
<p dir="auto">You can try. . . Change the transmit power of your AP</p>
]]></description><link>https://community.m5stack.com/post/14032</link><guid isPermaLink="true">https://community.m5stack.com/post/14032</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Tue, 08 Jun 2021 10:39:45 GMT</pubDate></item></channel></rss>
