    m5stack unitv2 AI Camera - getting started
    Modules
    6
    11
    16.1k
    • P
      patmolloy
      Just arrived. When I plug into a Windows 10 machine I see a device called USB 10/100 LAN with the yellow warning triangle. So no driver. Where do I find the driver, please?
      Also, by default should I be able to access the device via WiFI on the SSID M5UV2_XXXX ? I see no such SSID being broadcast.
      Thanks!
      Pat
      • m5stackM
        check the tutorial you will get the driver
        https://docs.m5stack.com/en/quick_start/unitv2/base_functions
        • nechryN
          nechry
          same issue for me, the device didn’t broadcast any WiFi. I can only connect via the USB ethernet Lan.
          Also, Is there a way to use the USB network adapter on OSX system?
          • itsover9000I
            itsover9000
            Same issue, im running a mac so i think hotspot connectivity is my only choice and im having same issue the wifi network is not available to connect ?
            • nechryN
              nechry
              I can’t see the ssid from my side. anything to active on the unit?
              any chance to get the driver for macOSX?
              • itsover9000I
                itsover9000
                Maybe for Mac os this is the driver http://www.corechip-sz.com/endownload.asp
                "SR9900 MacOS Big Sur Driver"
                Its not available to download for normal user.
                Thanks. Alex
                • A
                  albert8413
                  Hi allk. Same for me no Ap is broadcasted. Can ssh to the unit via 10/100 USB-LAN, but sudo is not working so even when finding the configuration for WLAN I think its not possible to change.
                  • m5stackM
                    we debug these issues now. we will release the new firmware update to fix it later.
                    nechryN 1 Reply Last reply Reply Quote -1
                    • nechryN
                      nechry @m5stack
                      @m5stack ok thank for the update. do you have a expected release date for the next firmware with wifi?
                      • m5stackM
                        m5stack @nechry
                        @nechry not yet. sorry. when we update it , we will public a post to the community.
                        • AsmodevA
                          Asmodev
                          Having a similar issue, I've got into the web server, but the AP isn't starting, I can't even find the AP ID or even tell if it's started?
