    M5Stack FIRE, faild to init PSRAM
    M5Stack Fire
    fire psram
    7
    9
    26.5k
    • G
      gombe
      M5Stack FIRE has a PSRAM, but it cannot read the PSRAM's device ID, and external memory test fail with numerous errors.
      Why?
      This is boot log when I try to boot micropython, PSRAM version.
      https://github.com/loboris/MicroPython_ESP32_psRAM_LoBo/wiki/firmwares
      Rebooting...
      ets Jun  8 2016 00:22:57
      rst:0xc (SW_CPU_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
      configsip: 0, SPIWP:0xee
      mode:DIO, clock div:1
      load:0x3fff0018,len:4
      load:0x3fff001c,len:4636
      load:0x40078000,len:0
      load:0x40078000,len:13040
      entry 0x40078530
      E (572) cpu_start: Failed to init external RAM!
      abort() was called at PC 0x4008197a on core 0
      0x4008197a: esp_dport_access_int_pause at /home/gombe/bin/esp-idf/components/esp32/dport_access.c:195
      Backtrace: 0x40094437:0x3ffe3c70 0x4009458f:0x3ffe3c90 0x4008197a:0x3ffe3cb0 0x400792f9:0x3ffe3cd0 0x40078591:0x3ffe3d10 0x40007c31:0x3ffe3eb0 0x4000073d:0x3ffe3f20
      • J
        jcsbanks
        https://mobile.twitter.com/M5Stack/status/1027828441653989376
        I ordered on Aliexpress 2 days ago, from Wavgat.
        Is their stock likely to be faulty? They did not answer when asked and sent it anyway.
        If faulty, is the solution to replace the PSRAM?
        TeresaT 1 Reply Last reply Reply Quote 0
        • loborisL
          loboris @gombe
          @gombe 在 M5Stack FIRE, faild to init PSRAM 中说:
          Why?
          I'm using an earlier M5Sstack model with PSRAM and it works without any issue.
          If you can build the firmware, you could build with VERBOSE LOG bootloader option to get more information about the PSRAM detection and the initialization failure reason.
          • L
            lelehel
            I have the same issue. I bought M5Stack FIRE in the Aliexpress Store and I get the same boot message..."Failed to init external RAM"
            I sent a message to the M5stack devs through Aliexpress but no reply. :(
            No PSRAM for me I guess... :(
            • TeresaT
              Teresa @lelehel
              @lelehel Hi My Friend, did you order it from our official store ? Please kindly send me an email attached your order# and screen shot of the error. I'll help to ship the replacement asap. My email address: teresa@m5tack.com
              • TeresaT
                Teresa @jcsbanks
                @jcsbanks Really sorry about the psram problem. The Wavgat store just one of our distributors. Did they refund or send you replacement ? Maybe you can open a dispute for help. If they cannot do any refund or replace, please contact me via teresa@m5stack.com
                • B
                  bonnom
                  mode:DIO, clock div:2
                  entry 0x40078530
                  E (679) cpu_start: Failed to init external RAM!
                  Rebooting...
                  Seems like I got the same problem, is it really that the psram is broken?
                  • m5-docsM
                    m5-docs @bonnom
                    @bonnom
                    Try this firmware
                    https://github.com/m5stack/m5stack-cam-psram
                    M5Stack documentation URL
                    https://docs.m5stack.com
                    • B
                      bonnom
                      I'll try that when I get home,
                      The m5burner from the m5stack download page. also has a check psram option and that showed this, maybe handy for people in the feature that want to check if it is working.
